Won’t stay running…
Old School AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Topic: Won’t stay running…
    Posted: 26 Sep 2024 at 8:38pm
I have an old d15, I believe it’s a 1962. The positive battery post touched and grounded the engine out…burnt the ground post off. I replaced battery end but now tractor won’t stay running. Runs for 1-2 minutes then shuts off. Any suggestions????
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 9:00pm
well with a shorted out battery cable, its probably not a fuel problem.. Electrical area... Coil , capacitor, starter key/ switch, wires...... When it dies, see if you have 12v at the COIL... if you do, then the battery / switch / key / wires are probably working right...
12v power to the coil , then check the FIRE at a spark plug.. If no SPARK, then you have a coil or capacitor or burn point problem... If you have NO POWER to the coil, then look at the key switch and the wire from the key to the coil.
--------One test is to take a jumper wire from the battery to the + terminal on the coil and then start the tractor.. That bypasses the key and wire harness to guarantee you have POWER to the coil.
Edited by steve(ill) - 26 Sep 2024 at 9:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 9:59pm
A model D-15 gas with a generator is a POSITIVE ground. So, how can the ground short out ??   Or, do you have an alternator conversion and now it is a NEGATIVE ground ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 59 minutes ago at 9:16am
Yes it runs on gas. I have an alternator with a separate Solenoid. The solenoid positive end touched the frame and the negative end melted from the battery. Yeah, yeah
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 52 minutes ago at 9:23am
Thanks Steve, I will try it this morning to see what happens. I’ll reach back out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 29 minutes ago at 12:46pm
once you get it going, you might find out the alternator has a problem... Solid state parts inside do NOT like shorts or sparks..... hope for the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 6 minutes ago at 11:09pm
Can’t get it to run correctly. I don’t know if coil, points, or carburetor is needed. I have no idea.
