Won’t stay running… |
Post Reply |
Old School AC
Bronze Level Joined: 6 hours 4 minutes ago Location: Florida Points: 2 |
Posted: 5 hours 45 minutes ago at 8:38pm |
I have an old d15, I believe it’s a 1962. The positive battery post touched and grounded the engine out…burnt the ground post off. I replaced battery end but now tractor won’t stay running. Runs for 1-2 minutes then shuts off. Any suggestions????
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80213 |
well with a shorted out battery cable, its probably not a fuel problem.. Electrical area... Coil , capacitor, starter key/ switch, wires...... When it dies, see if you have 12v at the COIL... if you do, then the battery / switch / key / wires are probably working right...
12v power to the coil , then check the FIRE at a spark plug.. If no SPARK, then you have a coil or capacitor or burn point problem... If you have NO POWER to the coil, then look at the key switch and the wire from the key to the coil. --------One test is to take a jumper wire from the battery to the + terminal on the coil and then start the tractor.. That bypasses the key and wire harness to guarantee you have POWER to the coil.
Edited by steve(ill) - 5 hours 20 minutes ago at 9:03pm |
Orange Level Access Joined: 12 Sep 2009 Points: 20191 |
A model D-15 gas with a generator is a POSITIVE ground. So, how can the ground short out ?? Or, do you have an alternator conversion and now it is a NEGATIVE ground ??
Post Reply | |
