won't run on non ethanol gas
conservationmN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote conservationmN Quote  Post ReplyReply Direct Link To This Post Topic: won't run on non ethanol gas
    Posted: 03 Jun 2023 at 1:35pm
My recently rebuilt B was running fine untill I added non ethanol gasoline.  I never  heard of this being a problem.
Engine misses under load  ( Load being trying to go down a paved street in 3rd)
Only other thing changed was adding oil to the air filter (I had been runnng it withoil until I patched a leak in the cap)
Thanks
Wally
Post Options Post Options   Thanks (0) Thanks(0)   Quote conservationmN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 1:40pm
Let me calrift
It was running good on 10% ethanol ( only this available here) I went on a trip and picked up non ethanol gas
Wally
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 3:51pm
should not make a difference... gas might be OLD... have a trace of water in it... got a spec of dirt in the main jet ... or just need to adjust the carb adjustable jet a 1/2 turn ??
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 5:33pm
or your oil is too high in the filter
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 9:58pm
I think you got some gas.                  MACK
Post Options Post Options   Thanks (1) Thanks(1)   Quote conservationmN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 6:33am
It turns out to be an ignition problem gas was a co-incidence,
