won't run on non ethanol gas |
conservationmN
Topic: won't run on non ethanol gasPosted: 03 Jun 2023 at 1:35pm |
My recently rebuilt B was running fine untill I added non ethanol gasoline. I never heard of this being a problem.
Engine misses under load ( Load being trying to go down a paved street in 3rd) Only other thing changed was adding oil to the air filter (I had been runnng it withoil until I patched a leak in the cap) Thanks Wally
conservationmN
Posted: 03 Jun 2023 at 1:40pm |
Let me calrift
It was running good on 10% ethanol ( only this available here) I went on a trip and picked up non ethanol gas Wally
Joined: 11 Sep 2009 Location: illinois Points: 90904 |
Posted: 03 Jun 2023 at 3:51pm |
should not make a difference... gas might be OLD... have a trace of water in it... got a spec of dirt in the main jet ... or just need to adjust the carb adjustable jet a 1/2 turn ??
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 03 Jun 2023 at 5:33pm |
or your oil is too high in the filter
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
MACK
Posted: 03 Jun 2023 at 9:58pm |
I think you got some gas. MACK
conservationmN
Thanks(1)
Posted: 04 Jun 2023 at 6:33am |
It turns out to be an ignition problem gas was a co-incidence, |
