Wobble |
Darrell G (MN)
Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
Topic: WobblePosted: 04 Mar 2021 at 2:02pm |
A friend of mine has a 8N ford and after about 8-10 mph the front wheels go into a death wobble, any ideas on how that can be fixed.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11401 |
Posted: 04 Mar 2021 at 2:06pm |
Where does the wobble start at steering box or tie rod ends
Darrell G (MN)
Posted: 04 Mar 2021 at 2:42pm |
Tie rods are solid, I think it starts inside the gear box
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 04 Mar 2021 at 4:56pm |
adjustments inside the gear box .........
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 04 Mar 2021 at 6:51pm |
Steve has probably got the info on it. Back in my day as a youngster, when you wore the box out that far you put your two feet up on the steering shafts and let her rip.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55278 |
Posted: 04 Mar 2021 at 8:37pm |
Hadda MF turf 20, like that, it would do 30-35 mph, with the road gears it had in it. Wobble started in the upper range! Maybe its time fer the universal ford fix! ![]() |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 05 Mar 2021 at 12:57pm |
I've always heard the way to fix a Ford (no matter what the problem) was to first find an abandoned quarry. Then tie the steering wheel of said Ford pointed in the direction of the abandoned quarry. Then after starting the Ford (if it will run, if not, push it), put it in gear and bail off
shameless dude
Posted: 05 Mar 2021 at 11:36pm |
X2 with Paul!
