wiring question for WD 12 volt |
Don(MI) ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Michigan Points: 3880 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Dec 2010 at 11:56am |
Just a quick dumb question. I will be wiring the WD tonight, this tractor was set up with a 12 V alternator previously, I changed that to a 12V generator. When wiring the amp, should the lead come off one terminal of the battery, and the other lead to the other terminal? Might sound dumb, but this really is my first wiring job!
Also, has anyone documented a wiring diagram for a 12V with generator?
thanks, Don
Roddo ![]() Orange Level ![]() Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
You mean the ammeter? Pick up power from the lug at the starter, run it to the ammeter, then take any other power wire to the other side of it, such as lights, ignition coil, etc for it to read properly. Are you going to a 12v neg ground as well? This site is ripe with info for many wiring related stuff for out old orange tractors.Edited by Roddo - 03 Dec 2010 at 12:09pm |
Yep, the ammeter. And yes it is a negative ground. Thanks!
Edited by Don(MI) - 03 Dec 2010 at 4:35pm |
