Wiring diagram for an Allis G
Skuter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Topic: Wiring diagram for an Allis G
    Posted: 03 Jan 2011 at 6:20pm
I was wondering if anyone had a 12v wiring diagram for a late forties Allis G
Thanks,
Skuter
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 6:39pm
Do you mean the sticker of the diagram that goes on the tractor or a printable diagram?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 6:44pm
A printable one.  My alt. died and got a new one, there's a plug that comes off of it, and the battery and ground terminal.  The person before me used the plug, and it looked like they grounded out the bat. terminal.  Seems like a weird approach so I wanted to see what a diagram would recommend...
thanks,
Skuter
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 7:05pm
If yours has been switched to an alternator from a generator the factory diagram might not help. I scanned the diagram but I can't find it in the computer so I'm not much help.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 7:36pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 7:50pm
Thanks I found that diagram with an internal regulator, I have an external regulator.   Where I am stuck has to do with the alt. and the amp meter (mine is disconnected).
I have a plug the plugs in back of the Alt. and a wire that seems to run from the Bat. post to a ground (next to the regulator) and nothing on the ground post.  So I'm unsure if the wire that appears to be a ground...be connected to the ground post and the bat. post on the alt. be left blank (because the plug takes care of it), or should I run a wire from the "bat." post on the alt. to somewhere, Plug the plug in, and run a ground wire from the ground post to a ground.
Thanks,
Skuter
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 8:01pm
give Steve a yell, I'm sure he'll know
Steve@B&B (973) 632-5596
customcircuits@gmail.com
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 8:09pm
Thanks Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 8:17pm
http://www.rowand.net/shop/tech/images/AlternatorWiringOverview-1963to1972Buick.jpg
MOST alternators are 12 volt, negative ground... you need to know before you wire it up.
Edited by steve(ill) - 03 Jan 2011 at 8:17pm
This page was generated in 0.445 seconds.
