Wiring Diagram CA with Voltage regulator wanted.
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Topic: Wiring Diagram CA with Voltage regulator wanted.
    Posted: 07 Mar 2010 at 5:08am
Hello,
Does anyone have a wiring diagram for a CA with a voltage regulator in the system?
The CA I have came with the voltage regulator... If I start it up and ground the field it pegs the amp meter in the discharge direction.... Wondering if the previous owner switched from positive ground on the battery to negative ground?
Wiring diagram would help....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 6:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 11:13am
With a regulator instead of the Hi Lo light switch, the wire going to the light switch from the generator is the field or "F" wire on the regulator. The larger wire going to the battery from the generator will go to the regulator terminal that will be marked "ARM" or "GEN". Then there will be a wire going to the battery through the ammeter connected to the "BATT" terminal.
First thing I would do is polarize the generator. It can work either polarity unlike an alternator. To polarize all you do is momentarily touch the BATT and ARM terminals together with a piece of wire. It will make a spark. You also will want to make sure the ammeter polarity is correct. Turn the lights on with the engine off. If the meter shows charge, reverse the connections on the back of it.
This page was generated in 0.270 seconds.
