wiring connectors
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: wiring connectors
    Posted: 18 Dec 2010 at 10:00am
Anybody know of a good source for good quality connector/terminals for wiring a tractor. I'm not impressed with the stuff available at the local autoparts store
Also, is there a 12v light bulb that will fit in the origional headlamp socket on the WD's
Edited by LouSWPA - 18 Dec 2010 at 10:13am
I am still confident of this;
Wait for the Lord;
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 10:13am
Lou, some electrical supply places for contractors sell a good quality line, along with heat shrink tubing to complete the job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 10:16am
Ya' Joe, I have found a few on line, I was just hoping to find someone that has first hand knowledge of one as it is difficult to get a feeling for the quality from a pic.
Thanks
Wait for the Lord;
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 10:32am
I use these guys alot http://www.delcity.net/
there's also http://terminalsupplyco.com/Default.aspx
both sell very good quality connectors, we use them both on our trucks at work
Edited by JoeM(GA) - 18 Dec 2010 at 10:32am
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 11:13am
Sta-Con connectors is what i bought for shop at work, used for all panels and such on industrial work, also used same in my own shop at home for many years. Come boxed in 100 pack though for most.
 Any electrical supply house should have them, come in both insulated and non, with full boot or just over crimp area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 11:22am
We use crimp on heat shrink connectors that comes from "Curtis". Far as I know they are a specialty supplier to the automotive repair industry. It depends on the type of socket your head lights have. 1156 is a 12V bulb that has 2 little stubs opposite of each other. If the original bulb has a large flange on it and uses 3 spring loaded pins, Steiner has them in both 6V and 12V. I have the 12V versions in my Oliver 60 head lights and they do put out plenty of light.
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 5:35pm
 I USE CONNECTORS FROM DIGI-KEY.COM. THEY STOCK A LARGE VARIETY OF INDUSTRIAL  ELECTRONIC EQUIPMENT.
WD,D17-S4,180,D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 9:00pm
Lou, Yes there is a 12v bulb that will fit the WD light socket. I don't know the number of it off hand but put them in the 45 about 10 years ago.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 11:39pm
  Hello Lou!!   Crimp, solder, heatshrink.  1156   the auto parts store should have a picture of blub bases, and candle power.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 12:53am
3-m makes great connectors
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 6:25am
Allen says it best. I prefer to 'tin' the wire first,then crimp, then solder,then heatshrink it.
Some call me 'anal' for doing it this way but it's a habit after 45 years and I've got better things to do than waste time redoing a 'quick' repair job.
By 'tinning' the end of the wire first, it seals the strands from wicking up moisture/water,which will corrode the wire from the inside out the entire distance causing no end of weird problems(kinda dim lights,charging 'problems',etc.)
 If you're going to be spending a lot of time restoring tractors or use them daily on the fields,take 5 extra minutes in the shop for a high quality,do-it-once-right repair.
Proved it  to a neighbour a while ago.His B wouldn't start, I told him to replace the original 'ugly' battery cables(naw, just needs a good battery...so he bought one,6Volt of course $$$),still wouldn't start. I went over to my CA(6 volt,3 yr old battery,seldom used),turn the key,pressed starter,ruuuumph ,purr,purr,purr.Stubborn guy ..he still hasn't bought new cables($20) so the B sits.
I'd hate to think how many connectors I've used in 4 1/2 decades but even the 'offshore' stuff is OK, if you tin-crimp-solder-shrinkwrap.The key is to keep the water out.
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 7:07am
Lou,
I found a bulb at napa that may work for you. It is a #LMP 1143.
Danny
I have also converted to a sealed beam in the orginal housing, I used 1/4" fuel line slit  down the center on one side to make the gasket for the sealed beam head lamp.
Edited by dannyraddatz - 19 Dec 2010 at 7:14am
Danny Raddatz
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 7:48am
Waytek is a good place to look for wiring supplies.
http://order.waytekwire.com/cgi-bin/lansaweb?procfun+wordpr01+webfunc+M50+FUNCPARMS+WEBCMP%28S0020%29:01+WEBID%28S0020%29:01
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 10:33am
find a company called HI-LINE they usually have a vendor truck like snapon or the mac tool truck.they have anythingand everything...they sell sets  or boxes  of assorted terminals and connectors,even envoirmental wire splices
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 3:29pm
jaybmiller says it best!!  If you don't have the time to do it right, how are you ever going to find the time to DO IT OVER??  This is one of my many slogans.  It has paid over the years.
roscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 8:45am
