Wirin' up the 620
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Topic: Wirin' up the 620
    Posted: 22 Sep 2015 at 10:29pm
Got some of the front wiring installed couple weekends back. Got the headlights in also. Should be able to see good with these bulbs. I specked out some aircraft landing lights. Still have to install the "lollipop" warning lamps on the tops of the fenders. Wiring is in for them. They're on a separate flasher circuit. Gettin' close to droppin' in the motor. Woo Hoo!
Steve@B&B
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2015 at 7:57am
Looking good Steve!!
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2015 at 8:12am
take lots of pics and post them up!
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2015 at 9:37am
any details on the lights?  part #, amp draw, high/low, etc?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2015 at 10:23am
Yes, looking good
Smile
Tom
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2015 at 9:35pm
Sure looks nice, Steve - BUT Mike Noonan has 4 front hydraulic lines on the 720 he is working on.  Better install a couple more now - much easier, right? Only need another valve. LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 6:39am
Dave,
The lamp is a hi/low lamp used in Marine and Aircraft taxi or landing lights. 100Watt 13V. narrow long beam. Wagner or GE# 4700. I wired em' on the high beam side. I'll see how they work out on the machine with the Stator system. I still am looking into designing an Alternator system for these model Tractors if its possible. Once I get my engine back in, I can work on that. I have a pile of parts in a box that I've compiled over the past year or so to try this feat...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 10:01am
Steve,
 Sure looks nice! Going to be a great looking tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 6:14am
Thanks Chris! Takes a while to get em' in shape. You know that! You have a couple of nice WD's there you put a ton of work into...
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2015 at 11:54am
steve here's led headlight options that are supposed to be a direct fit for hundered series tractors.  just scroll down
http://www.tigerlights.com/category-s/1867.htm
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 6:54pm
Sure would be nice to have an alternator system. If anyone can do it you can. Go for it.
This page was generated in 0.609 seconds.
