Wires like spaghetti
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: Wires like spaghetti
    Posted: 12 hours 50 minutes ago at 8:03pm
The starter on our Kenworth T300 stuck on this morning.  We were only moving the truck into the barn, but when we shut the truck off, the starter was still running.  I quickly disconnected the battery negative cables, and it shut off.  Took the starter out, and the solenoid is bad,  so I will be replacing that momentarily.
The starter is a Delco 37MT model, that has a ground stud on the starter body.
When I took off the wires from the Solenoid positive terminal, and the starter body ground terminal, I marked them appropriately.
Here is the question.
Is there anyway to know for certain that the wires are truly were they belong (ground vs hot)?  The truck has had lots of weird electrical issues (mostly in the cab), ever since the starter was first replaced about 5 years ago.  (I am wondering if the techs that replaced it put all the wires on the correct terminals.
Thank you,
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 35 minutes ago at 8:18pm
I'd have to see pictures of what you have  and even better the wiring diagram for your truck.
I can't see why the starter would have a ground wire. If it does, it's got to be big and fat to handle the 200-400 amps to spin the starter.
Usually starters with internal solenoids will have a big stud( +12 battery) and a small stud or spade connector( low current, from 'start' position of ign switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 31 minutes ago at 8:22pm
is this your starter ?
if so
top big stud  goes to battery +12
btm big stud goes to ground, battery -ve
little stud ,upper right, goes to 'start' position of ignition switch or 'push to start'
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 4 minutes ago at 8:49pm
you might be able to trace a couple wires... should look somethink like this.. you may not have the thermostat connector
https://www.delcoremy.com/documents/starter-instruction-sheets/over-crank-protection-installation-42mt.aspx
Edited by steve(ill) - 12 hours 1 minutes ago at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 55 minutes ago at 9:58pm
Jay,
Yes, that is what the starter looks like.  Steve, yes, similar diagram.
When I took the starter out, it had 3 wires on each post.  The + at the solenoid had the Battery Pos cable, plus two smaller wires, and the ground post on the starter had a battery negative, and two smaller wires.
The ignition wire was on the small post on the solenoid, and then the other small post of the solenoid had a wire going to the large ground post on the starter body.
I don't have any pictures right now, but can get some tomorrow.  The wires are extremely dirty, so it would take a little work to get colors of them.  Plus, Kenworth doesn't have any wiring diagrams that are of any value.  When I call for a diagram, they say that every truck might have a different wiring, so they can't tell me what it would be like under there.
Thank you
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 45 minutes ago at 10:08pm
looking at the wire diagram... and your description... It sounds like everything is connected correctly... and you might have an EXTRA ground wire ... which is OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 34 minutes ago at 10:19pm
When I took the starter out, it had 3 wires on each post.  The + at the solenoid had the Battery Pos cable, plus two smaller wires,( yes, the yellow and purple with battery cable) and the ground post on the starter had a battery negative, and two smaller wires.  ( yes, the GROUND cable and the red plus an extra --- if you dont have the thermostat switch, then the bLACK wire from the magnetic switch MIGHT be connected to the BIG GROUND terminal on the starter.)
The ignition wire was on the small post on the solenoid,( the green)  and then the other small post of the solenoid had a wire going to the large ground post on the starter body. ( yes, the red)
Edited by steve(ill) - 10 hours 32 minutes ago at 10:21pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 54 minutes ago at 12:59am
Seen a few where that secondary solonoid is used in tandem with main solonoid on starter , positive shot off of voltage to starter to prevent overrun that destroys starter windings . Some reason the dependence of main solonoid to not stay engaged is overlooked .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 4 minutes ago at 6:49am
Love Steve's diagram ! The magnetic switches 'ground' stud goes to that 'themostat' in the starter then to ground. That way when the starter overheats,it opens the path and you HAVE to wait until the starter cools down before trying again.
The extra 2 wires on both +ve and -ve posts sound like someone at sometime added 'stuff' and this was an easy place to get 24/7 battery power.
If you leave the 2 small wires off the +ve post of the starter, engine should still fire up fine. What won't work will be whatever extra 'stuff' the PO added. Maybe a backup camera system, extra lights, CB radio , ??? It'll be obvious when 'it' doesn't work anymore !!
