windshield and cold
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: windshield and cold
    Posted: 10 Feb 2021 at 8:37am
Other day had a small chip or crack form in center bottom of windshield while driving - by the time I got to destination it became a crack about 1" along bottom on drivers side about 1/2 way across . Next day it took off the other direction across passenger side again about 1" from bottom .
 Yesterday when I went to eye doc that right side crack made a U turn and started back to center . Then as it was dark out just as I turned into drive to house I heard a ting noise - but didn't see where the thing cracked this time - and light snow on windshield now so unseen where it went .
 Was figuring i would wait to have it replaced until spring but looks like that's a No Go
Jeep Cherokee with built in wiper defroster which is suppose to keep wipers from icing up when parked .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 8:52pm
Wonder if the wipe blade heater is causing enough temperature differential to cause the cracking. Once a crack starts running it can go all over the place. I didn't even know they had wiper defrosters.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 9:38pm
My Subaru had those built into the front window.  They are like the rear window heaters but only down low on the front. There is like a mat area. I sure miss those.  Gave the car to my son.  I never had any problems with them causing a problem.  Did get a crack once and had to have the window replaced, but it wasn't from the heater.
