Window Gasket replacement
Jclodfe2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jclodfe2 Quote  Post ReplyReply Direct Link To This Post Topic: Window Gasket replacement
    Posted: 25 Jan 2025 at 3:54pm
I’m replacing all window gaskets on a year a round cab and the rear window is a slider that needs a brand new gasket and I’m having trouble with locating the correct gasket. Any help would be greatly appreciated. Thank you, Jason
ValleyFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ValleyFarm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 5:09pm
Have you checked your local auto window/ windshield installer or auto body shop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jclodfe2 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 5:13pm
I checked an auto glass place yesterday and they said they would do some checking and the next time to bring in the frame and old gaskets so they could see it. I’m going to sandblast and paint all of the frames so I’ll do more research when I’m ready for glass.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 10:25am
The window seals and door seals are just foam stripping with the peel-off backing. At least that's what my YAR cab has had since new. Available lots of places. The back window is a whole different deal. Actually 3 are used on mine. The entire back window is hinged at the top to swing open and will use the same foam stripping as all the others. Then there's the rubber seal that actually holds the glass in. And then, there's the felt-like seal that the sliding glass is nestled in. Since YAR has been gone for years now, the back glass seals are next to "nonexistent".
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 10:46am
You can look on Grainger or McMaster-Carr.
They sell some glass/window seals
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
This page was generated in 0.211 seconds.
