will wc f&h steel wheels clear fenders on my rc?
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: will wc f&h steel wheels clear fenders on my rc?
    Posted: 18 Jun 2013 at 8:29pm
would like to pull steel wheel with my rc,i no the bolt pattern is the same but will they clear the fenders.just wonder if somebody has tried this so i no if it will work or not.thanks
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 7:14pm
Late production RCs used the same brake cover casting as a styled WC with spacers to move the fender closer to the tire. If you have that style just remove the spacers. If you have an earlier RC change the brake covers for ones off a styled WC. Of course you might have enough clearance with things just like they are... just do a trial fit to see! Kip
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2013 at 8:06pm
If I can find it I have a picture of a wide front RC on full steel. That ought to show you what you need. Now if i can find it,,,
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2013 at 7:07pm
Mike,  they will bolt up without a problem, not wanting to discourage you, but I think you might be pretty light on power to pull that on steel, Those lugs eat horsepower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2013 at 7:13am
yes you are probably right im building a motor for my b and ill just pull that on steel sometime.just wanted to try it.thanks for the info.
