Will the AC 5050 hydraulics run a BH 2446QT loader |
Dammbut
Topic: Will the AC 5050 hydraulics run a BH 2446QT loaderPosted: 28 Jan 2024 at 4:28pm |
Are the hydraulic ports above the PTO able to run a Bush Hog 2446qt loader?
If not, any suggestions as to a PTO hydraulic pump? I can fab a tank, and have located some pumps that will move 21gpm if needed. |
I M Fedup
Joined: 01 Jul 2020 Location: Winchester Ky Points: 28 |
Posted: 28 Jan 2024 at 5:19pm |
Will it operate? Yes, but the tractor has only about 6GPM oil flow available so it won't be very fast moving.
There should be a cover plate above the PTO shaft. Under that plate is the top drive shaft fro the PTO. There were some pumps that could be fitted in place of the cover that drive off the shaft. Might be an option for if you care to play around with that.
Dammbut
Posted: 28 Jan 2024 at 9:54pm |
Okay, so I should investigate a 21gpm pump then. Being 55yrs old I don't have much time left to be waiting on a slow loader...lol!
Thanks for the info on the top plate. As I have found, any of the original AC pto pumps are difficult to come by. If I can scare up a pump I can fab a coupler for that would be optimum. |
