will it work
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Topic: will it work
    Posted: 16 Aug 2011 at 1:18pm
will a wd head go on a 37 wc
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:45pm
Don't think so.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:48pm
i dont think so either but try telling my boss that lol..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:50pm
completely different CI and hp aren't they?
German Shepherd dad
#WD234847
#WD88193
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:51pm
Yes, a 15 stud head will work on a 12 stud block, But you have to plug the three 3/8 diameter stud holes with a cork.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:55pm
would it be easir to just buy a rebilt wc head.. since the wd head we have has like 6 stuck valves. he said the wd head was rebuilt but it sat outside for awhile and is rusted.. or how much do you think it would cost to rebuild the wc head..?
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:55pm
Depends how old of WD we are talking.  The older WD should be the same head as a WC.  I believe only the newer WD's had the three 3/8 holes.  Old WD had a 3 inch tall head same as WC, newer had a 4 inch which would require you to get longer studs, or headbolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:58pm
the wd head is 4 inch and the wc head is 3 inch....
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 2:30pm
The early WDs (up until "Engine" ser.#WD289001) used the 3" head like the WC.
The change occured sometime in mid 1951.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 3:29pm
All you need is the longer studs and it'll go right on.  Like someone else said, cork the 3/8" holes and your good to go.  FOr the record, a WC and WD are both 201.  There was about 5 horse difference between them, I think.  The WD45 was a 226 from the 1/2" more stroke.  Anything in the W series will swap into another with the acception of the early year WC's had smaller main journals.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 6:04pm
thanks yall
