Will it pull it??? |
jbirnsch
Joined: 02 Jun 2010 Location: Egg Harbor, WI Points: 78 |
Topic: Will it pull it???Posted: 01 Dec 2018 at 3:06pm |
cwhit
Posted: 01 Dec 2018 at 3:10pm |
You bet. If not ,by a performance chip. lol.
TimNearFortWorth
Posted: 01 Dec 2018 at 3:18pm |
Sure she'll pull it but stopping it with the hand brakes may pose a challenge . . . .
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 593 |
Posted: 01 Dec 2018 at 3:19pm |
NO fear if that is empty and on the flat...
jbirnsch
Posted: 01 Dec 2018 at 6:50pm |
It has a Gleaner E engine, M code, in it. Maybe a beacon will help too. |
tomstractorsandtoys
Posted: 01 Dec 2018 at 6:53pm |
Sure it will pull it all day long just don't even think about filling it.LOL Tom
Dakota Dave
Posted: 01 Dec 2018 at 9:22pm |
If it's on flat concrete and the tires are fully inflated you could pull it with a garden tractor.
Unit3
Posted: 01 Dec 2018 at 10:18pm |
At first I was going to say no, but then I saw you have a 12v alt. If you can power the tail lights, drop in a hitch pin, hook the safety chain, grab a hand full of throttle and dump the clutch. A 6" flame will appear from the stack as the radiator cap rises skyward. Good luck. God speed.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24735 |
Posted: 02 Dec 2018 at 6:02am |
OK guys...kinda curious... just how much would it weigh filled with grain ? I'm thinkin g'going' isn't the problem... STOPPING is !
cwhit
Posted: 02 Dec 2018 at 6:50am |
500 bu. corn @ 56 lbs. per bushel = 28,000 lbs. plus wagon 3000 ( guessing) = 31,000 lbs. Might need fluid in the tires.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Posted: 02 Dec 2018 at 7:11am |
I've moved loaded 550 bu wagons around a gravel yard with a WD that had fluid in the tires. Did some spinning to get started. Truck tires on the wagon help a bunch. AaronSEIA
jaybmiller
Posted: 02 Dec 2018 at 8:12am |
thanks for the numbers !! Yeesh that WOULD be quite a load to get moving and it'd never stop too quick !! Jay
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Posted: 02 Dec 2018 at 9:24am |
I think the wagon weighs closer to 6000. I was thinking about buying one before harvest.
bigal121892
Posted: 02 Dec 2018 at 10:26am |
Wagon is just shy of 5900#.
Edited by bigal121892 - 02 Dec 2018 at 10:27am |
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 02 Dec 2018 at 10:32am |
But if you put fluid in all four tires.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4756 |
Thanks(1)
Posted: 02 Dec 2018 at 8:28pm |
Gee you people of no faith,
sure it will stop somewhere. You just may not like where. Or has gravity gone the way of climate , and had a change.
dano-59
Posted: 02 Dec 2018 at 9:08pm |
looks dangerous!!! Had a co-worker loose his life in a under size tractor without ROPS an a half loaded grain cart .Tractor spun out on an incline ,drug him backwards, tractor jackknifed and overturned
shameless dude
Posted: 02 Dec 2018 at 11:59pm |
should pull it the same as if i'd hooked my Buick hearse on it!
chaskaduo
Posted: 03 Dec 2018 at 9:44am |
Is that a dead on pull Shameless?
Edited by chaskaduo - 03 Dec 2018 at 10:05am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12232 |
Posted: 03 Dec 2018 at 9:52am |
Heck yeah it'll pull it. To where you fill it!
dano-59's story reminds me....I'm sure this thread is meant in jest, but still. 2 years ago I was spreading lime. The spreader was the design where PTO operates the live bottom as well as the slingers, so to get the correct rate, you have to drive a given ground speed. I was using a tractor that "would pull it".....I gave my sphincter quite a work out when I came to the end, the slight side hill and other conditions were "just right" and when I began the turn that thing shoved the ass end of the tractor straight and began to jack knife it in a hurry. If I hadn't been leery of what could happen, might not be typing here right now, taking my meals through a straw and unable to wave buh-bye.
fourthgeneration
Posted: 14 Dec 2018 at 6:01pm |
There are worse ways to die I guess.😉
