Will a B handle this?
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Will a B handle this?
    Posted: 14 Jun 2018 at 8:18pm
I found this on LSN. I've got enough bush hogs, but not one that will work on the B. Can anyone tell me anything about these mowers? It looks like it uses a hydraulic cylinder. Maybe I can get a manual device to raise and lower it.
http://www.lsn.com/equipment/allis-chalmers-bush-hog/5801958.html
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 8:26pm
They are really good cutters but I wouldn't want to have to use it behind a B.
ldposse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ldposse Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 8:38pm
I have an older woods 5’ bush hog that I have used behind my B. It works but I generally need to keep it in 1st gear.
http://www.youtube.com/watch?v=fQsdYlS4I7o
Edited by ldposse - 14 Jun 2018 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 8:39pm
That is the main reason I was interested in it. I don't have any equipment for the B and a pull type cutter is all you can use. I don't know how heavy that bush hog is, and the B doesn't have a ton of power. The D10 would handle it I know, but I have a 3pt cutter for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ldposse Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 9:01pm
If you don’t already have it, you’ll want to install a PTO overrun clutch. I had to have an ASAE adapter made for mine, mower sat way too close to the tractor without it.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 10:20pm
What year is your B? I say it will. You might be surprised with the guts a B has. If worse comes to worse, just take a little smaller swath. Get it. You'll be glad you did.
I remember when I didn't have any implements for my B, and it was the worst feeling ever, to have a tractor but not be able to do anything with it. I was 11, and I would go out in the barn and just stare at it, because really that's about all I could do, other than just drive around the yard. Soon after my grandpa found a 6' belly sickle mower for it which put me in heaven, then later Dad bought an Oliver 2-12 plow, which I really enjoy using. I also use it to pull a trailer sometimes when doing yard cleanup/tree trimming. Being able to use your classic for something other than just parades is, to me, quite gratifying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 4:45am
That 160 pull type should have a built in ORC.  Its at the end of the drive shaft, before the rattle clutch.  Still, as others have mentioned, B would have barely enough power...Cry
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 5:20am
Believe it or not it depends on what your trying to cut and how high ,Thumbs Down  LOL
  Waist high thick grass with dull blades? Nope
 Clipping pasture? Yep
 Maintaining an area that you cut regularly? Yep
  Not having live power to get you through the tough spots hurts the B on that kind of work. At the farm we keep about 6 acres mowed, normally once a month  and use a 6' Brush Hog. The D-15II is the primary power but I would not hesitate to put the B on it if the 15 was down, been done quite a few times over the years.  I raise the mower up a few cranks and mow in low gear. The"cheat" if need be is as  Creston said, move over and cut less
Edited by Butch(OH) - 15 Jun 2018 at 5:20am
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 5:48am
The AC ones have an over running clutch in them.  You would be best off to have the 1 3/8" PTO shaft on the tractor, but can use an adapter.  You can buy a manual turnbuckle to put in place of the cylinder.  I did that when I pulled one with my WC.  Run it high, multiple passes, and narrower than full width and you should be ok.
AaronSEIA
T.J.-N.J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J.-N.J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 6:38am
I regularly mow with a 5 foot brush hog behind my C with a worksaver 3 point on it. It gets light in the front end if you try and carry the whole mower but with the top link adjusted right and the mower sitting on the caster wheel it does just fine. Sharp blades are your friend as there isn't a lot of horsepower to spare with a B or C engine. TJ
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 7:13am
why not use the Hydraulics on the B and a loooong hose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 8:43am
Not all B's have hydraulics.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 4:36pm
The parts book is online (guest user, free, no sign up) at AGCO parts books.
Looks like they had a manual option, and hydraulic.
I didn't immediately see an over run clutch in the book. Find it in the parts book, then ensure this mower has it. Could have been another option.
I think maybe you can flip the wheels around to get them to trail the mover and not stick out like it is currently set.
The B could do it, on light work. Not 3" trees in 4ft weeds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 4:48pm
it will cut a field that is 18- 24 inches deep.. Don't try trees as mentioned.. use a floor jack to lift and figure out where you want it, then just put a solid link where the cylinder goes.. always cut the same height... good first test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 9:28pm
My B has hydraulics, It just doesn't have a remote. It doesn't matter anyway. I checked the map to see were that town was (Lavinia), and it's way out in west TN. No where near me, I don't have time to go that far to check it out.
