will 190 pull a #2018 disc
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: will 190 pull a #2018 disc
    Posted: 03 Dec 2009 at 10:19pm
I have found a #2018 disc, but was wondering if a 190 (not xt) has the power to pull a 18' disc.  I kind of figured it did, but wanted to double check.  we have mostly sandy loam soil.  The 190 has loaded rear tires and rear wheel weights.
Thanks
Adam
John_SWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_SWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 10:46pm
I pull 13 feet through hard clay in 6th gear all day long.   I'd guess it wouldn't have a problem in sandy loam with an extra 5 feet.
John-
"If I can't fix it, I'll fix it so no one can."
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 11:05pm
We had a 190xt with a 13 foot disk . like John said no problem in 6th . but i wouldnt pull an 18 footer .. just my opinion
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
StanOhio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanOhio Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 11:47pm
Hi Adam, I pulled an 18ft ford disk with my old 190 XT and I have clay/muck, kind of heavy and hard. First time over was no problem but had to drop a gear or take some angle off the gangs to go over it again. I would try it, if it works, happy day, if not, sell or trade for a smaller one.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 11:57pm
My 190XT gas pulled a 15 foot in 6th with no problem. I'm sure it would pull an 18.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 6:23am
It depends a lot on the disc.  Don't put an 18' Kewanee 1010 hydrofold behind it, because it will park you even with duals.  Been there, done that.
BigBadAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 8:30am
I think that will be way to much disc for your tractor.  You want to be able to pull the disc in multiple conditions and have the angles on the gangs set for proper discing and be able to pull it at the depth that you need.   If you're not discing deep enough or have it set properly, you're just wasting time and money.  We have an AC 2500 21' centerfold and there's times when we wished we had more on it than the 8070.
Also if your pulling that old of a tractor to it's maximum limit all the time you will end up with a broken tractor and a large repair bill.
Best regards,
Jason
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 8:32am
If I take the wings off and take it down to 14' would that be a better match?
Thanks
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 9:13am
Yes that's more realistic.  We used to pull a 13' Oliver with the AC200
Jason
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 10:01pm
An XT would probably handle it (like some have said).  But yours is not an XT, so I would doubt it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 10:04pm
I have a 15 foot AC disc in good shape I will sell. It does not fold. Tracy Martin
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 10:25pm
Why sell the disc?  Just get a bigger tractor :).  I bet a D21, 210, 220, or 7080 would look good pulling it to name a few.
1979 Allis Chalmers 7000
5800 Hours
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 1:00pm
just leave the wings up and when you get in conditions where you can pull it or you get a bigger tractor there they are
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 1:29pm
It just depends on what you're wanting the disk to do.  If you're just chopping up residue or leveling a seed bed 3 or 4 inches, no problem, but for primary tillage 6-8 inches, you'll need that D21 or 220.  I think the 14' would be alot better.
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 4:25pm
We have a 15' allis man fold disc and you better have 100 h.p. in loose dirt (Ky clay) and a good set of tires. A 14' fixed wing would be better like the other guys said.
Chad S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 5:20pm
I would think you would be ok.  I have pulled our 25' 2500 disc once with our XT and boy was it a load in 6th gear but I only had 10 acres to do and that tracor was the only one not hooked to anything.
36 WC,41 WC,53 WD45,57 D14,65 D21,68 XT,72 XT,81 7045
