Wife decided, Roughing it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Wife decided, Roughing it!
    Posted: 12 Apr 2025 at 12:34pm
Tonight. Going to sleep Inside the Trailer aside the shop. Still access to full lavatory in that building as need be but she feels a necessity to tey it out and see what shakes out overnight.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 12:50pm
Enjoy
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 1:22pm
Trial runs sounds better than assuming good to go. Put to the test. There will be enough surprises when thinking all is well.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 4:15pm
We do that every spring to give the RV a shakedown.  Water, elec, generator, batteries, chasis eng, etc.  Finding a problem on the road only intensifies it with no tools to repair.  Spring/ice-out close to home also gives us a chance to shake it out and test out the fishin equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 4:15pm
Found a First Hmm moment today.  Drained Pink A-Fr from water system and tanks, kept seeing dead flies and gnats in Front Fresh Tank drain water(Kitchenette Sink), stopped as it got empty and pulled it, lo and behold Vent Line WIDE OPEN 3/8 tube, several dead flies still in line.  Used a piece of Scotch Brite pad and a piece of Aluminum Wire to secure it in the entry point for both tanks.  Supposed to have a metal either brass or aluminum screen in that vent opening, this will have to do.  Did pull both then Bleach shake and wash followed with rinse them out, reinstalled.
Before Ask or Note, SCH!TTERS FULL, Rinse flowed all the plumbing, Drained ALL the Catch tanks into buckets(Down the Shop Toilet) and all ready for the weekend at Shut Ins.
Edited by DMiller - 12 Apr 2025 at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 7:51pm
SCH!TTERS full... LOL, hope it has not been sitting a long time that way.  It can get VERY rank!  One trick I learned long ago, drain fully when close to full, then fill atleast 1/4 full of plain water.  Then throw in a 1/4 cup, 1/2 cup, depending on how big tank is, of Dawn and 1/4 cup of Calgon.  Empty at next destination then put another 1/4 tank of water in black tank.  The only time to let sit empty is winter/below freezing, period, or it takes for-ever to get that horrid smell calmed down.  Don't fall for the hype some stinky stuff must stay in tank for it to work... RV black tanks ARE NOT septic systems.  Another thing, don't leave black tank, ie ter, dump valve open when connected in a camp ground.  That will lead to other problems with your system.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 11:27am
Do you think the flies drowned in the water or did the antifreeze kill them? asking for a friend Wink
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 4:24pm
DAN !!! .. Now THATS FUNNY !!  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 4:49pm
Perhaps a Little of Both!!  Big smile
Anywho, all that is fixed.  Uneventful more or less night, Quiet, Cool Inside as had not started Furnace, 57 nearly all night outside, SWMBO had window ajar for a Light Breeze to keep her cooled off below Lava Heat.  A FEW Hormone issues as an Older Gal.
Generally sleep on a Sleep Number Air support mattress, her side near to 80, my own at 55, memory foam was OK, not what I would consider as a Permanent mattress but fine here, as well I Had Sheet AND a Blanket over me.  That is until 11:40 as was awakened as blanket got tugged to herself.
Slight Off Angle to RV, she kept rolling to center of Mattress, would wake up as elbowed me inadvertently moving about and going back to her side.
Decided to go to Lesterville after ate breakfast and scope out the Park grounds at the Shut ins for our soon to commence two day camp out.  2.5 hours down, easy to find, roads in campers area near to Perfect as just completed in 2009 to replace the old blown out camper area to the south of hwy72 that the Taum Sauk incident took completely out.  Should be a good initiating trip.
Edited by DMiller - 13 Apr 2025 at 4:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 10:37pm
Dave... every time you said "SHUT INS" i though "gee... i know that name, but why"... your last post filled in my blank spot.... That has been a few years back!
In December 2005, the Ameren Reservoir, setting on the Peak of Proffit Mountain, breached. The 1.3 million gallons of water being held back by the reservoir's wall was unleased down the side of Proffit Mountain and into the valley of Johnson's Shut-Ins State Park.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 3:03am
That would be it.
The old park RV campgrounds was obliterated and is now called the Debris or Boulder Field, getting down to the actual Shut Ins area is a jaunt but worth the few minutes to run around inside the park.
Ameren footed the bill to construct the new RV Grounds and a number of hiking trails, the visitor center tells of the debacle of the reservoir failure. Opened eyes and management minds as to actually fixing not patching the mechanisms that earn their livings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 12:17pm
Park Run was a WIN WIN.  Wife Enjoyed the trip and we have scheduled Trip number TWO, to Eureka Springs AR.  Will be Staying at The Kettle Campgrounds, pull thru slot, should fit nicely.  Have ordered a Different Ramp system, will have to add Hinges and make Two into a Folding One as a Alternate to what Folded Up on First round.
Funny a Simple 900lb Harley could do this!
Did ride to Elephant Rocks SP, not been there since was 14, changes little but little changes go a Long Way.  Shut Ins area at the park was closed off due to potential of Flash Flooding, did get to run around and do some walking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 12:19pm
Site was Inconsequential to access or egress.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 10:49pm
One thing about it.....cruising anywhere is effortless. Probably just enough weight on the drives to give a good ride. See that hill up there! What hill!! PFFFT!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 3:44am
As we came home, the rains turned on.  The route was MO 72 to MO 49 thru Viburnum to Cherryville, then N to the home place up MO19.  Had three other RV draggers, a Jeep, and a crew F150? and some smaller car with smallish single axle units, as left 72 they vanished in the mirrors.  As we stopped at Viburnum to recheck the Bike tie downs the pickup went past, was around ten to fifteen minutes behind, the Jeep caught up as we sat in Cuba getting the wife a Fountain Coke, they were somewhere around 20-30 minutes behind.  Not ever saw the car again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 4:04am
Bought a pair of 15" wide 3000# aluminum ramps, will add either a set of SS Hinges or aluminum Angle or pipe for a Cross Pin to hold together as a hinged pair of single ramp 30" wide.  83" or just under 7' long should remove some of the severe angle at the threshold and strong enough not to bend to bupkus.  Weight is 53# for the two, be here on the 15th.
This page was generated in 0.168 seconds.
