Why single front wheel? |
nowaktj ![]() Orange Level ![]() ![]() Joined: 13 Dec 2009 Location: Elk River, MN Points: 732 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jul 2011 at 2:43pm |
Guys-Wondering why some of the tricycle tractors had a single front wheel. What was the original purpose of this design?
Thanks in advance
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Uh oh! There you gone and dun it! You asked the age-old question about single front wheels. That'll open a can of worms, I tell ya!
I think it has to do with Eistein's Theory of Relativity.
You see, you get your relatives to lay on the ground whilst you run over them with the single front wheel!!
Sorry, I couldn't resist.
To make it easier to cultivate vegetables and beets and things in narrow rows.
Narrow rows.... But don't forget about crops grown on raised beds - the area between the beds isn't wide enough to fit 2 tires in (like a conventional narrow front), and if you use a single tire, the tractor will more or less 'steer itself'..... |
Austin(WI) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 1460 |
So you only had to fill one front tire when it went flat instead of two
"Better By Design"
ky wonder ![]() Orange Level ![]() Joined: 13 Apr 2011 Location: horse cave, ky Points: 647 |
here in ky they where used for cultivating tobacco, the single wheel would let you get another pass at cultivating the crop without damaging the growing leaves, which is the part you sell.
a lot of farmers would remove one side of a regular two wheel tricycle front to get the same option
i like old tractors of all colors
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
they also said the single front wheel worked better with a mounted corn picker was not supposed to ball up in southern IOWA gumbo soil
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
all the things listed above...also, alot of farmers used to pack their just planted rows of seed, to expedite the seed to start growing, and the single front wheel did better than the 2 front wheels. so...each pass would pack 3 rows. had to plant pretty even as planters planted in groups of 2's...2-row, 4-row, 6 row...on up, and packing was done as 3-rows, 5-rows and such...some did make a 4th row packer wheel mounted on the back, using a truck wheel.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
That's what my Dad thought one muddy fall (M Farmall and a 2M picker) it was as bad or worse until he put a smaller tire on it. In normal conditions, it made following the row easier as cultivating would leave a furrow in the middle. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
JeffHillNC ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: maysville, NC Points: 60 |
Back years ago when I was young my uncle bought a wd45D from another ac farmer for the front wheel, the engine was frozen and split so we pulled the front pedastal and wheel to put on a wd we used alot. The biggest difference we saw was putting out nitrogen to corn. At fast speed the single wheel didnt kick and buck the steering wheel as bad and in moderate soil actually would track by itself alot of the time.
Qualityusedmowerparts.com
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Back when white navy beans were grown in this area, the single front was often used on the tractor used on the bean puller.
Dusty
Auntwayne ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
The only bad thing that I can tell you about the tricycle front wheel is : Do not forget to use the right and left brake pedals while cultivating near the outhouse !!! Believe me, you will not turn, as the top soil is pretty loose after doing the end rows first. Took out a fairly good chunk of it !!! I do hear about it to this day !!!
junkman ![]() Orange Level ![]() ![]() Joined: 02 Mar 2011 Location: Nevada, MO Points: 355 |
Auntwayne your experience makes me wonder who still has a outhouse? I almost hit mine with the d17 the other day.
Ed ![]() Bronze Level ![]() Joined: 30 Nov 2009 Location: Amory, Ms Points: 28 |
All D Series one row cotton pickers had the single wheel...worked great with
a 4-row cultivator!
Ed
trikesbikes@gmail.co ![]() Bronze Level ![]() Joined: 23 Feb 2023 Location: Minnesota Points: 15 |
What is the weight difference between a single wheel front and the weight of the narrow front WD 45 and or The single wheel front and a wide front WD 45 thanks
Also is any for sale single wheel front for WD 45 thanks
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4063 |
Well, I assume they are somewhat lighter than a tricycle front, maybe someone here knows the weights? They do come up for sale once in awhile, always seem to bring pretty good coin.
Had a couple response but I didn't know that it's cast iron so not saving any weight thanks for the response!
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21836 |
About as "light" as you can get and still look "stock" is use a narrow front end assembly from a WC as they are quite hollow inside and weigh 90 lbs or so LESS than a WD45 narrow front.
Any pacific year? Thanks for all the Post you put on hear save Alot of Head aches and pocket books!
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5012 |
I have no experience with the WD / WD45 single front wheel, but I have a CA with a factory single front wheel. The single wheel is VERY heavy. Unless the WD is different, I'm betting the single front wheel isn't much lighter than the narrow front, unless you can replace the wheel with something much lighter.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3895 |
i had the single front wheel off a massey harris 44 about a month ago to do wheel brgs. and paint and i could barly lift the tire and wheel/ i would almost bet its heavyer than the narrow front with tires and wheel , the yoke that the wheel goes on was made out of real heavy sized steel
Thanks for the info!
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 954 |
I've a D15 1 with SFW has 9.50x10 tire, manual steering, 13.6x28" rears. Its Wheel assy is heavy and the cast fork that holds wheel & tire makes it heavier than a std NF end. The steering gear leaked when I got it so took it apart. The tire size is hard to find. It's hard to steer in soft soil, the D17 I w/ NF & man'l str is far easier to steer.
I've papers from when it was sold new, equipped as it is, I'm second owner.
