Why is 13.6 equal to 12? |
StanGreen ![]() Bronze Level ![]() Joined: 13 Nov 2022 Location: US Points: 60 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Nov 2024 at 10:50am |
As I am looking at new power shift rims for my WD45, I have figured out that my 13.6x28 tires need to go on 12x28 rims. I am just curious as to why 13.6 tires need 12 inch rims?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21747 |
They don't NEED 12 inch rims. That is what the tire makers recommend for best performance. You can mount them on 10 or 11 inch or even 13 inch if you want. The tire doesn't know or care.
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
The tire sizes listed in old books were based on a different design standard. If you use tires on the rim width listed it gives the best geometry. Some real old rims like on my WC don't fit modern tires exactly but that's all you can do.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87287 |
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8008 |
Tires that get put on rims that are wider, tend to have the tire sidewalls too straight. Which can affect the way the tire tread grips the soil, and adversely affect tire wear, plus straight side walls may give a ‘firmer’ ride.
Maybe I've misunderstood the original question. Prior to about 1958 a WD/WD45 tire size was called a 12-28 size tire. From about 1958 and newer, the tire industry began a new tire size system and what was a 12 x 28 now became a 13.6 x 28. Both sizes are the same actual size. A-C in about 1955 (WD-45) began advertising an optional 13 x 28 tire on a 12 inch rim. This new optional size would later become the 14.9 x 28 tire in 1958. In my mind the 11 x 28/12.4 x 28 tire was on a 10 inch rim. The 12 x 28/13.6 x 28 tire was on an 11 inch rim. And the 13 x 28/14.9 x 28 tire was on a 12 inch wide rim. After all these 70 or more years you will find ANY combination out there !!!
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3869 |
if you are a little wider and change to 14.9 somtime it will work out a little bettter
