why B swing hitch missing center hole |
conservationmN ![]() Bronze Level ![]() ![]() Joined: 14 Jan 2022 Location: wisconsin Points: 15 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Feb 2023 at 5:54pm |
Why isn't there a hole to pin the swing hitch to the center?
( Obviously I don't use my tractor for farming!) Wally
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
Wouldn't be a 'swing' hitch then. Might have something to do with the distance of the drawbar hole from the PTO. G https://www.mecum.com/lots/GF1115-225552/1948-allis-chalmers-b-wide-front/ Edited by Gary - 22 Feb 2023 at 6:03pm |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88286 |
If you want it to not swing MUCH.. just drop a bolt in on each side of the bar and limit the travel to a couple inches... If you want it MORE SOLID.. bolt a small plate to each side so the bar can not move sideways.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3939 |
if their was a hole in the center it would break in two in a haertbeat
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54308 |
I think there's a bracket that can lock it to center, as others have said, if there was a center hole, breakage likely...
Does your Original Drawbar have the 2 smaller holes, 1 hole each side of the larger Centre Hole, similar to the hitch in the picture I posted ? If so, drop a bolt into each smaller hole. G |
Thanks All, for the replys
This is a new tractor to me so I haven't much work for it yet. It seamed as if would be difficult to back up a trailer with the hitch swinging from side to side. I see the swing can easily be limited but wondered why not in the center. Thanks
Wally |
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8116 |
The smaller Farmall’s (400, Super M, 656) where I worked years ago, all had ‘swinging drawbars, tho we never let them ‘swing’, two bolts with a plate under.
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11772 |
WD’s and ‘45s didn’t have a center hole, either. A clamp that straddled the drawbar, or just two bolts was used, depending on how rigid a connection needed.
Edited by TramwayGuy - 23 Feb 2023 at 10:32pm |
Dave (Mid-MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Hemlock, MI Points: 569 |
The swinging drawbar was an option that bolted to the regular drawbar, which is bolted to the final drives. If you don't need the swinging drawbar for your application, bolt it to one side and use the center hole in the regular drawbar.
JSHIVERS ![]() Bronze Level ![]() Joined: 24 Jun 2021 Location: Bloomington,IN Points: 73 |
I found out what a swing hitch was last summer at a tractor show
when I got too close and wracked my shin! Does that count?
