why B swing hitch missing center hole
conservationmN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote conservationmN Quote  Post ReplyReply Direct Link To This Post Topic: why B swing hitch missing center hole
    Posted: 22 Feb 2023 at 5:54pm
Why isn't there a hole to pin the swing hitch to the center?
( Obviously I don't use my tractor for farming!)
Wally
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 6:03pm
Wouldn't be a 'swing' hitch then.
Might have something to do with the distance of the drawbar hole from the PTO.
G
https://www.mecum.com/lots/GF1115-225552/1948-allis-chalmers-b-wide-front/
Edited by Gary - 22 Feb 2023 at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 7:26pm
If you want it to not swing MUCH.. just drop a bolt in on each side of the bar and limit the travel to a couple inches... If you want it MORE SOLID.. bolt a small plate to each side so the bar can not move sideways.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 7:36pm
if their was a hole in the center it would break in two  in a haertbeat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 8:56pm
I think there's a bracket that can lock it to center, as others have said, if there was a center hole, breakage likely...
Gary View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 6:36am
Does your Original Drawbar have the 2 smaller holes, 1 hole each side of the larger Centre Hole, similar to the hitch in the picture I posted ?
If so, drop a bolt into each smaller hole.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote conservationmN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 4:42pm
Thanks All,  for the replys
This is a new tractor to me so I haven't much work for it yet. It seamed as if would be difficult to back up a trailer with the hitch swinging from side to side. I see the swing can easily be limited but wondered why not in the center.
Thanks
Wally
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 9:13pm
The smaller Farmall’s (400, Super M, 656) where I worked years ago, all had ‘swinging drawbars, tho we never let them ‘swing’, two bolts with a plate under.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 10:30pm
WD’s and ‘45s didn’t have a center hole, either. A clamp that straddled the drawbar, or just two bolts was used, depending on how rigid a connection needed.
Edited by TramwayGuy - 23 Feb 2023 at 10:32pm
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 7:12pm
The swinging drawbar was an option that bolted to the regular drawbar, which is bolted to the final drives. If you don't need the swinging drawbar for your application, bolt it to one side and use the center hole in the regular drawbar.
JSHIVERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2023 at 10:39am
I found out what a swing hitch was last summer at a tractor show
when I got too close and wracked my shin!  Does that count?
This page was generated in 0.127 seconds.
