Who repairs worn pedals on WD
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Who repairs worn pedals on WD
    Posted: 16 Nov 2025 at 2:17am
I remember there was a member on here that could repair badly worn clutch and brake pedals on WD series tractors. I have a couple that are in need of repair and haven’t seen anything mentioned on here in a long time wondering if he still does them and what his contact info is. tia
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:05am
A good machine shop could easily take your pedals and machine/install bushings in them to fit the new shaft.  Probably even drill and tap for a zerk.
AaronSEIA
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:04am
AaronSEIA
x2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 3:36pm
70233270 bushings from a D-17 clutch pedal work I think. Takes two per pedal and grind off any excess.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:24pm
I used McMaster part 6391K649. Two per pedal and cut off for length.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 6:35am
Rtool on here was repairing them.
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 8:42am
I have a related follow up question.  The diamond plate pattern is worn off from the pedal itself, making the pedal really slippery when wet.  My bushings are ok.  Short of finding a set of pedals off a salvage machine, anyway to restore the pedal surface itself?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:31am
Welding criss-cross lines on it? Confused
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 11:50am
I refurbish the WD/WD45 clutch and brake pedals and make new shafts that the pedals ride on. Send me a PM if interested. Or call me at (269) 8zero4-5984.
Ray W.
