White tractor Fuel injection
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: White tractor Fuel injection
    Posted: 10 May 2021 at 8:12am
I know it's the wrong color, but allis shares many of the same parts I'm struggling with.
My white 2-70 the pipes hooked on the roosa master injection pump leak. They have ever since I got it back from the repair shop. I'm referring to the little short pipe that's held on with a banjo bolt. The injection line screws on this.
Also I noticed that my return line keeps leaking. I'm having a lot of trouble with those rubber t boots that connects one injector to the next.
Any help on either problem would be great.
When I get this fixed I've got a line on my 2-135 white that needs to be replaced. I think it's cracked. I can loosen the nut at the injector then tighten it again and it will be fine for a little while.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 9:07am
Did you use new copper washers on both the inside and outside of the injector lines? It's imperative you use new ones every time you remove them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 11:15am
I believe he used aluminum??? I'm not positive. I know he used new ones but I'm certain they were not copper. Will copper be ok with diesel fuel?
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 4:54pm
A lot of engines use copper.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 8:33pm
Every one of them I've been around including AC, Oliver, JD, and IHC use copper washers. I've never seen aluminum used for this purpose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2021 at 10:50pm
Well....you can't get a normal torque wrench on them on the back side but I think my 220 service manual says something like 35ft/lb on them. Though they were tight with hand wrench but tried the T/W and they went a good bit more. Maybe you don't have them TIGHT!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2021 at 12:40pm
Those washers are supposed to be steel, and I tighten them as tight as I can get with a regular 9/16 wrench. A 2-70 is a 1655 with a new dress, great little tractors!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 10:05am
As Ed says,the latest are steel
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2021 at 12:47pm
On related note, is a 2-135 basically the same as MM 1355?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2021 at 3:05pm
Not at all. A 2-150 is exactly the same as a G1355 except sheet metal/cab, and some updated issues. The 2-135 and 2-155 are the same basic tractor as one another, but was a totally new design, larger trans and rear end with inboard planetary final drives and wet brakes. This drivetrain is what they used for a long time afterward. The DA 9130, 9150, 9170, 9190 etc. Great drivetrain! The 2-135/155 shared the Hercules engine 478 cid from the oliver 2050/2150.
