Whiskey Throttle Vid |
Beirnesy
Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
Topic: Whiskey Throttle VidPosted: 18 Dec 2016 at 8:05pm |
seen this on you tube and thought I would share
Edited by Beirnesy - 26 Dec 2016 at 12:49pm |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55204 |
Posted: 18 Dec 2016 at 8:25pm |
[TUBE]xAOOIk_fAvY[/TUBE]
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 18 Dec 2016 at 9:13pm |
Repowerd with cummins on alky
7040
Joined: 11 Aug 2013 Location: newglarus wi Points: 418 |
Posted: 24 Dec 2016 at 12:17pm |
Green county machine built that 5.9 Cummings repower
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Posted: 25 Dec 2016 at 7:57am |
Does he use a 185 rear in that tractor?
bsallis180
Posted: 25 Dec 2016 at 8:47am |
Yes from bell back it's orange
mf440
Posted: 25 Dec 2016 at 3:10pm |
From front of trans back lol. The bellhousing / power derector housing is missing has a clutch can
KevinON
Posted: 25 Dec 2016 at 4:44pm |
Who makes the clutch can??
DougG
Posted: 25 Dec 2016 at 5:26pm |
Really do tell on the parts needed since the PD is missing;
mf440
Posted: 25 Dec 2016 at 5:37pm |
clutch can/ SFI bellhousing , input shaft with an adapter to the transmission
DougG
Posted: 25 Dec 2016 at 5:59pm |
Yes who makes an SFI clutch can for these?
mf440
Posted: 25 Dec 2016 at 8:26pm |
Probell or any other manufacturers and any good machinist can make the rest of the parts needed to make it work.
Larry W.
Posted: 26 Dec 2016 at 12:29pm |
You can make most any bellhousing work, mopar or chevy steel bell housing and custom backer plate for the motor
Jerald/KS
Posted: 27 Dec 2016 at 12:58pm |
Whisky Throttle is our old Orange Crush light super. It was set up with with a re drilled rear plate and a Hemi clutch can, crower 3 disc clutch, chevy gear reduction starter, Pro Fab 2 speed, solid driveline and couplers to allis input shaft. All gears in allis trans removed. Ran a final gear ratio of 19-1. Our second tractor Smokin Assets was set up the same, but even removed axle tubes and machined aluminum adapters to mount finals directly on rear end housing.
Acllss puller
Posted: 25 Jan 2017 at 8:14pm |
How much ton build another set of aluminum adapters?
