whiney steering hydraulics/190 gas
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: whiney steering hydraulics/190 gas
    Posted: 30 Aug 2010 at 9:49pm
I've went through a lot of work to quiet the cab of my 190 gas; lots of sound guard insulation, triple layer floor mat, headliner, all glass in good shape, and for the most part it is very quiet inside. But, the steering motor gets one heck of an annoying high pitched whine to it most of the time, that I'd desperately like to get rid of. It kind of changes pitch when you turn the steering wheel, and some times a change of engine RPM's will eliminate for a short time, but it always seems to come back. Any one have an idea for a fix for this problem. My 190 XT diesel doesn't have this noise to it, so I would assume it does't have to be there. Thanks in advance for any and all help.    Darrel
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 7:48pm
It's actually a steering valve and not a motor.  there are several possibilities;
It may be a clogged hydraulic filter causing the releif valve to open in the steering system.
A bad releif valve
Flow divider not working correctly
Power director valve problem
Bad steering valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 11:54pm
Thanks, Joe. I have changed the main hyd filter, and I don't think there is another one, is there? As far as the other components that you mentioned go, is there anyway to trouble shoot them one by one without just simply replaceing them?   Darrel
