Which oil for torque housing and trans
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Topic: Which oil for torque housing and trans
    Posted: 04 Mar 2022 at 2:21pm
Gotta put fresh oil in my trans and torque housing. It's an early 190xt. #7229. What should I be running? Can imagine what it's going to cost. Diesel went to 4.69 a gallon today. Gonna be expensive spring planting. Oh well, tell me what Yas think. Thanks, John
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 2:49pm
You need a hydraulic/transmission fluid that says it meets Allis Chalmers (or AGCO) Power Fluid 821 specs. It should say so on the side of the pail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 3:22pm
How about Chevron the 1000. I can get a small 30 gallon drum of that. Looks like Agco says it meets 821xt specs. Whatever that means.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 3:23pm
Meant Chevron thf 1000.
Edited by John m - 04 Mar 2022 at 3:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 4:14pm
If it meets AGCO 821 or 821XL or Permatran specs, it's good to go.   5 gallons in torque tube...….8 to 10 gallons in trans differential.    Final drives are 2 gallons each and normally are 80/90 wt gear oil, but really don't know why all the compartments couldn't use the same 821 oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 4:37pm
Thank you, I was hoping you would respond. It says it meets 821xL specs so I'll go with it. Kinda nice because that's what's used in our other 4 tractors. Thanks for responses, John
Edited by John m - 04 Mar 2022 at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 4:45pm
any "QUALITY" oil will meet 20 different manufacturer specs... Most of them are very similar if not identical.... Allison C3, CAT TO2 , CASE HYTRANS.... and dozens of others.. They will ALL be listed on the back of the drum.
for example.......
Edited by steve(ill) - 04 Mar 2022 at 4:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 4:53pm
If the jug or barrel is " generic hydraulic / trans  fluid".... and has NO SPEC on the label, then it is not QUALITY oil..
Edited by steve(ill) - 04 Mar 2022 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 5:14pm
Pure Flo 334 has always worked for me,
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 2:47am
who produced the 821 fluid for AC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 8:05am
I don't know, but when they've had 821 since 1967/68, I'm sure there has been more than one supplier over all those fifty plus years. Current oil is Perma-Tran thru AGCO.
Edited by DrAllis - 05 Mar 2022 at 8:06am
