Where to get bearings
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: Where to get bearings
    Posted: 15 Sep 2014 at 12:39pm
i am working on an allis H4 Crawler steering clutch. I need the throw out bearing and the pilot bearing that goes inside the hub of the steering clutch also I need some new bolts for the rear sprockets. where is the best place to order them and the cost. thanks norm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2014 at 3:01pm
If you have part numbers or bearings have numbers - a bearing house or even NAPA can find them .
 Other option is MINNPAR in Mpls MN as OEM supplier of HD4 parts and will have most things . Bolts a fastener house can help for the Grade 8 parts you need or again back ot MINPAR.
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2014 at 8:40am
If you order from Minnpar, get ready to spend money.. They charge insane shipping rate ($10 for a simple o-ring) and tack on a $5 service fee for any order less than $50.
I'd recommend a local bearing house if possible.
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2014 at 7:20am
We stock the bearings 989-3792721
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2014 at 8:33am
Thanks for the replies . I have them now. norm
This page was generated in 0.352 seconds.
