Where to find H3 Transmission Input Shaft Seal? |
tmd42024
Topic: Where to find H3 Transmission Input Shaft Seal?Posted: 21 Oct 2018 at 2:05pm |
Does anyone know where I can find a H3 Transmission Input Shaft Seal? I have a 1961 H3 dozer with the 149 gas engine; and, it is weeping hydraulic oil. The book indicates that the input shaft seal part number is 242624; and, the flange gasket for the input shaft is part number 0237197-5. (I guess if I can't find the flange gasket, I can always use silicone.)
Thanks for your help! |
Jim.ME
Posted: 21 Oct 2018 at 5:53pm |
Check with suppliers on this site like DJs and Sandy Lake for a couple. That gasket and seal were used on the D14s, and possibly others, as well. I bet you will find them. If you don't find the gasket I would suggest getting some gasket paper and making one rather than using RTV/silicone.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55262 |
Posted: 21 Oct 2018 at 5:58pm |
Once you take the old seal out, I have found that most quality old school parts guys can find seals, off of the numbers stamped on the seal. I'm not talking about a advance store, or o'reilley's, I mean a good auto parts jobber, or a rural NAPA. Or a bearing supply warehouse.
Also, once you have it off, you can see if something like a worn bearing caused the seal to go bad, or if you need to put a speedy sleeve, on a scored seal surface, of the shaft, in question...
tmd42024
Posted: 22 Oct 2018 at 7:18am |
Thanks much for your help - I called Sandy Lake and they had the parts in stock!
