Where to buy Tie Rods?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Where to buy Tie Rods?
    Posted: 05 Feb 2011 at 9:10am
They have them on ebay but I know we have some suppliers here....I need one, maybe both tie rods for my WD45 WF.....PM me with prices or let me know places they arent terribly priced....mine are seized and I cant get the one to loosen up to widen the front and the ends arent very good.....thanks for any help.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:30am
You tried Sandy Lake? Places like Valu-Bilt may not be any cheaper than AGCO. There's a small AGCO dealer in Indianola Ia, (R&R Equipment) same town where Valu-Bilt is, that usually can beat V-B's prices, sometimes by quite a bit.   When I replaced the outers on my CA I found that hammering on the tube rolling it around broke the rust grip and they came apart. It did take a little effort. A little time on a belt sander removed all of the hammer marks.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:59am
I ordered new ones from OK tractor. I replaced all 4 at the same time .
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 12:10pm
the last set I purchased would not clamp tight enough to hold so I tack welded it on top so I could grind off easily so length could be changed.  I even put new bolts in(original were chinese, and wouldn't you know it, the new bolts were too)!  When are Americans going to get enough of this stupidity and demand american made products with some quality.  Their steel is in between aluminum and low grade steel; easy to drill and easy to cut threads and easy to strip!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 12:23pm
  WE HAVE NEW IN STOCK   MALES AN FEMALES   1-800-254-3116
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 1:05pm
I got a set from A&I for my WD45 and I am quite happy with them.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 5:34pm
I have a used set, [ original AC ], think they are pretty good shape if my memory serves me.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 6:01pm
To get them to extend,soak with good penerataion oil then lay on solid surface such as anvil and hit with adout 1 lb hammer. Keep hamering and it will cause outside to strech and loosen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 6:43pm
I know how to loosen them and the one is but you didnt read the whole way through....the ends are pretty rough and not very tight....I want a new or used set that are nicer than these....Chris/CT can you check and send me pics to CHFCRes4cue@yahoo.com? thanks
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 7:44pm
When you change them, save the original clamps from the stock tie rods, they hold a lot better that the ones that come with the new tie rods.
This page was generated in 0.281 seconds.
