Where to buy ca engine rebuild kit?
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: Where to buy ca engine rebuild kit?
    Posted: 9 hours 30 minutes ago at 11:49am
I'm going to rebuild my ca engine, need a complete overhaul kit. Where are some places to buy a good quality kit? I'd like to hear your experience, the good and the bad. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 52 minutes ago at 12:27pm
i am guessing that most of the kits are made in the same factory overseas... all in the $500. price range... You will notice that original B had 3-1/4 inch bore.. C and CA had 3-3/8 inch bore... All aftermarket "KITS" for those engines are 3-7/16 bore... all the same compression ratio.... possibly someone has something different, but i think "most" of the kits are all the same... just pick a good vendor of your choice.
these would be pistons, liners, rings and gaskets... You buy the valves ..... and bearings seperate depending on the condition of your crank.
Edited by steve(ill) - 8 hours 50 minutes ago at 12:29pm
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 23 minutes ago at 4:56pm
Give sandy lake implement a call. Purchased 185 overhaul kit from them no problems
