Where to buy ca engine rebuild kit?
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: Where to buy ca engine rebuild kit?
    Posted: 08 Dec 2025 at 11:49am
I'm going to rebuild my ca engine, need a complete overhaul kit. Where are some places to buy a good quality kit? I'd like to hear your experience, the good and the bad. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2025 at 12:27pm
i am guessing that most of the kits are made in the same factory overseas... all in the $500. price range... You will notice that original B had 3-1/4 inch bore.. C and CA had 3-3/8 inch bore... All aftermarket "KITS" for those engines are 3-7/16 bore... all the same compression ratio.... possibly someone has something different, but i think "most" of the kits are all the same... just pick a good vendor of your choice.
these would be pistons, liners, rings and gaskets... You buy the valves ..... and bearings seperate depending on the condition of your crank.
Edited by steve(ill) - 08 Dec 2025 at 12:29pm
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2025 at 4:56pm
Give sandy lake implement a call. Purchased 185 overhaul kit from them no problems
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2025 at 10:55pm
We sell both 3-3/8" piston/sleeve kits and the 3-7/16" overbore piston/sleeve kits. I'd definitely recommend buying from a business that uses what they sell on their own customer repairs! That would be A&W Tractor or oktractor.com
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2025 at 12:16pm
We have a couple different options available if you are still looking for that OH kit.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2025 at 12:53pm
thanks for the POST ALex... i didnt know you could still get 3-3/8 inch kits... Wonder why they sell both ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2025 at 7:35pm
I choose to sell both in my store to offer the customer different multiple options to best suite their needs. The original kit is slightly more fuel efficient, and the oversize kit will give slightly more power. We dynoed a B this fall that we rebuilt with the oversize pistons and it was showing 21hp right away. That will go up a few points after the engine is broke in.
www.awtractor.com
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2025 at 7:44pm
Thanks for the info. So, would the Agco dealers basically offer the same aftermarket parts or would they be higher quality parts for the extra cost from a dealer?
