Where 'O where do these gaskets go?
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Topic: Where 'O where do these gaskets go?
    Posted: 01 Apr 2010 at 3:13pm
D17 series III gas.  Oil pan gasket set.  I know the two long gaskets go on the side, the other 2 medium sized cork gaskets go on the curved portion of the oil pan, but where do the little C shaped felt gaskets go?  Also, how do I hold the cork gaskets in place?  Would some black RTV sealant work?
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 3:53pm
The felts are the rear main seals - you have to split the tractor to put them in.  I"m waiting 'til I get my spring kleenup done, then pulling the loader off, splitting the old girl and putting in the felts as right now she leaks like the Exxon Valdez.
I put the end cork pieces in a small can and left them rolled up for a day or two before putting them it.  Gets them kinda round anyway.  I tried the RTV, didn't work for me.  Weatherstrip glue works good, I was able (with help) to hold mine in place whilst hoisting the oil pan up - slowly.  It is a real dance to get them in place and stay there.  When tightening up the oil pan, the front one on mine wanted to squirt out - I hadda put in back in place a coupla times.
It's not fun, but after a while you get the hang of it.  Hope I never have to do it again.
cheers,
Creek
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 3:56pm
Do not use silicone. If you don't put on a thick bead it will not spread {Crush} even and will cause leaks.
I use Permatex High-Tack to hold gaskets in place.
Could that 2 piece seal be the rear crakshaft seal?
Edited by Jeff Z. NY - 01 Apr 2010 at 4:48pm
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 4:06pm
I buy the AC pan gaskets because it has the little clips that hold the flat corks to the curved oil pan and have the E shaped gasket for under the rear main bearing cap.  The little clips make it sooo much easier!!!! Should be thick and thin felt seals, thin ones are for WDs and WD45s,  thick ones are for D17 and 170s.  HTH
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 4:13pm
Tie gasket with sewing thread. works fine ,saw dad do it over 65 years ago.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 5:01pm
on the flat gaskets use 3m weather strip adheasive just on one side apply and lift gasket so it gets a little air and then press firmly down to oil pan in the corners use just a little silicone the 3m adheasive is also known as yellow snot sold at napa
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 7:50pm
  hold the end pieces in place with a piece of pvc pipe   4" let it set overnite clamped in place  that is what we done at the dealer or 4" pipe works also
