Where is gasket cement required?
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Where is gasket cement required?
    Posted: 26 Dec 2010 at 6:06pm
Hello,
I am nearing completion on the engine rebuild in our first Allis Chalmers 160. I'm getting ready to replace the gaskets around the oil pan, timing cover, rear oil seal, etc...
Should I be using gasket cement on any of these gaskets, it sure seems like I was scraping enough cement off some of these surfaces during disassembly but the I&T book makes no mention either way so I figured it was a question worth asking.
Anyone?
Thanks!
Erik
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 6:13pm
Are you refering to something like "high tack" or aviation gasket sealer? I use that stuff alot just because i can't afford to do things twice. I don't know too many places that it will hurt as long as you dont use too much. All you need is enough to make the piece tacky.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 6:57pm
I typically use a purple anerobic gasket sealer (if I could just rember the name, $20 a tube from Loctite)  in areas where there is a seam,  like on an oil pan gasket where the timing cover or rear plate meet the block.  Otherwise I seldom use any sealent.
I commonly use a thin layer of grease on both sides of some gaskets to stick them in place and it makes it easy to take off for the next fella.  After scraping and sanding away at some tough old gaskets and you'll appreciate the ones that peal off easy.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 7:51pm
I use high tack on one side of the gaskets to hald it in place.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 8:19pm
  our dealer ship used alumium paint in the 50's -60's    used them over just more paint will always come apart too  we still do it today  know  you fellas do not beleive me huh
  this is older most of you
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 8:37pm
I will vouch for the High Tack as well! Great stuff for holding and sealing gaskets. For wide seams and gaps a dab of RTV fills the bill.
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 8:51pm
trick to RTV is spreading in a rel thin film, not thick bead, then letting it glaze or set for 10 minutes or so to film, then install , if it oozes out then you have it to thick and will find it migrating inside where you don't want it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 4:16am
Another vote for high tack for basic gaskets as pans, timing covers with rtv in the junction corners; for all tin gaskets as head gaskets on the old flat heads a good coating of Copper Coat sealant to keep the liquids in the engines.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 8:21am
Eric
I am in the process of finally putting my D 15 back together.  What d you think of the IT manual you are using.
I think my Gensales bok is kinda lacking for putting the puzzle back together after too many years.
If you think the book is great/good where did you get it?
thanx
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:14am
Norm has a few years on me, but I remember my first car. I couldn't keep a head gasket in it. I tried everything, including having the head milled. Someone who was familiar with the engine told me to spray both sides of the head gasket with aluminum paint with two coats, drying between coats. My seventh head gasket lasted until I sold the car for $35.00 (it had not blown). But this was the head gasket only. Bob@allisdowneast
This page was generated in 0.054 seconds.
