wheelie bars |
farmer_rob
Joined: 11 Sep 2009 Location: N.Lancaster ont Points: 362 |
Topic: wheelie barsPosted: 11 Sep 2009 at 11:56pm |
just wondering if someone could post some pics of how they have there bars set up.. i was thinking of bolting mine up to where the lift arms were .. i would then make it into a weight bracket in the process.. by the way its a wd45.. what angle do u come off from the back . i know the feet should be about 5"x5" but how far off from the ground.. thanks guys
Posted: 12 Sep 2009 at 7:23pm |
Center of the pads need to be a minimum of 32 inches rearward of the center of the rear wheels and cannot be more than 10 inches off the ground. They should also be 20 inches inbetween the center of each pad for width. They also should be able to jack up the rear wheels off the ground when tractor is at it's maximum pulling weight. If they can't do that, they may fail when you need them.
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 12 Sep 2009 at 7:40pm |
Thats good info from dr. allis but i also would like to see some pics for wheelie bars for a wd 45..
