Wheel Weight |
Post Reply |
PDehring
Bronze Level Joined: 06 Jun 2018 Location: Central MI Points: 93 |
Posted: 17 Jan 2020 at 6:42pm |
I found a set of weights that have a casting number of 254134-2 and have BW cast into them as well. Anyone know what they fit?
Yes, I looked on the weight page on here.
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21443 |
I'm thinkin maybe a picture or size/shape might help jog the grey cells here.Ballpark weight ? Qty per wheel ? All I know about weights is you MUST check the nuts/bolts every so often as any loosey goosey and the rim will be ,um, compromised.....
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5169 |
Link to 'that other' web site: https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=1962949 |
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 812 |
Not much to go on? # of bolt holes, distance center to center on opposing holes, inside diameter, outside diameter, thickness, approximate weight and of course pictures if possible would help.
Your number is very close to weights I have on a late AC200 and early 7000 tractors. They have weights with; BW 254136-2 on them, yours likely were made about the same time. They have 6 mount holes, 1.75" to 2" thick, 24" OD, 10" ID, and 14.5" bolt spacing.
PDehring
I found them on a pallet and didn't have a tape measure on me so the casting number was all I could get.
They did have 6 bolt holes and are similar to those dimensions so probably fit a 190/200 |
levipatch
Bronze Level Joined: 05 Jan 2019 Location: North carolina Points: 46 |
Not a wheel weight Question exactly, but how much (gallons ) Fluid should be in a 16.9x 28 tire. One of mine is about one third ,the other none I think. looking at the sweat mark.... D 17 ser 4 diesel. Im guessing the one third is 50 gals or less . Don't really know what they should have on average...Thanks Billy
Billy..Big cam 300, bcam 400,,941 CAT.,,Deere excavator..900 row crop.. 66 D 17 diesel IV... 985 Pratt and Whitney..4360 Pratt and Whitney... gitten tired !
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 943 |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
Do they look heavy ? As in 275 lb heavy for one weight ?
PDehring
I don't think they were that heavy, I was able to move one around. Probably 150lbs, but I dont know for sure.
Edited by PDehring - 18 Jan 2020 at 6:15pm |
levipatch
Thanks Got it now
DougG
If they are the 6000 series , lockable ones , they are worth some $$$
Post Reply | |
