Wheel weight bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Wheel weight bolts
    Posted: 12 hours 55 minutes ago at 1:48pm
Looking for 70-223565, front wheel weight bolts for a D14. Need 6. If you have one but it’s not for sale please give me the measurements of it, I’m guessing I could use a carriage bolt and grind the side off to fit.
Thanks
Robbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 29 minutes ago at 4:14pm
I used square head bolts and did some "blacksmith" work on them. Heated the head and a bit of bolt up till red and then gave it a good whack on the anvil with a large chunk of metal on the bolt shank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 52 minutes ago at 4:51pm
I wish I had one to go by, I do remember the offset of the head. Could also just cut the side of it off but I need to know the size of the bolt and length. Maybe dad’s D15 SII bolt would be the same? I will look it up on Agco parts-book. His weights are on the inside. I think it has the offset as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 49 minutes ago at 8:54pm
D15 is a different bolt so that won’t work.
This page was generated in 0.126 seconds.
