Wheel Pusher Bolts
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Pusher Bolts
    Posted: 13 Jun 2025 at 2:22pm
Has anyone made their own pusher bolts for changing wheel width? I need to widen my 190xt some but am really not interested in paying $150-$200 for 3 bolts. Looks like I could make my own for a lot cheaper.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 4:46pm
Maybe you are that talented. They must be at least a grade 8 bolt and they must be machined correctly to work.
Edited by DrAllis - 13 Jun 2025 at 4:46pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 4:54pm
If I sent them to you, can I trust you to send them back when you’re done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 5:25pm
If one would machine down the end of a grade 8 bolt to the pusher bolts profile, what's left can't still be grade 8 can it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 5:36pm
That’s what I was thinking. I just need to know the length and diameter of the bolt and diameter of the milled down shank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 5:38pm
Thanks for the offer but I would be afraid I’d break one! I wouldn’t feel so bad if I break one that’s mine.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 6:58pm
I found that to be an interesting question! Since I know a little metallurgy, but in a completely different arena, I looked a little bit. It looks to me like Grade 8 bolts are through hardened, whereas Grade 5’s not quite. So in that sense it seems like they would still be Grade 8.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 8:55pm
Have you tried A&W Tractor near Shawano, WI? Only 1 hr away from you! https://awtractor.com/product/wheel-jack-bolt-235674/
www.awtractor.com
A&W TRACTOR 920-598-1287
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 9:44pm
Better check the thread pitch. I dont know about the 190 bolts but im pretty sure the are not standard pitch on the 7000/8000 bolts
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2025 at 9:52pm
Thread pitch are normal 3/4" NC on those smaller bolts.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 6:35am
If you had a good machine shop cut down the ends of the bolts and explain exactly what you need it shouldn't change the grade if they went slow and didn't get the bolts too hot.
Going back about 40 years but think we used a grinder to cut the ends down to get the hubs loose on our D19.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2025 at 7:10am
I made a set for my D-19 and they worked just fine! Grade 8, coarse three. Good luck!
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 56 minutes ago at 11:20am
  Do you need dimensions? If you do I will try to find mine and take some measurements.
Edited by lentsch - 12 hours 53 minutes ago at 11:23am
WD,D15,190XT,7000,8010x2,7060,8070
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 17 minutes ago at 3:59pm
I looked at mine today, grade 8, but the threads start at the base of the hex head.
a bolt that long would not usually have threads the full length of the bolt. Just something to consider if you make a set. I thought I had an extra set to sell but I don't. I have a spare set of 70xx, 80xx I would part with
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 36 minutes ago at 5:40pm
Ive got 3 lathes and I bought mine from agco. Firstly I know they will work. Secondly by the time I find fully threaded grade 8 bolts long enough,spend the time to turn them I can have 3 or 4 sets of wheels moved and if I count my time on the lathe i wont save any money
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 52 minutes ago at 6:24pm
Not to mention breaking up a bunch of carbide trying to turn material that hard
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 60 minutes ago at 7:16pm
I wouldn't know where to look to find a full thread Gr8 3/4" NC bolt 6 inches long anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 11 minutes ago at 8:05pm
Try the Bolt Depot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 48 minutes ago at 9:28pm
McMaster Carr has grade 8  all thread rod in many lengths.Its what I used to solve the problem of the 3pt bracket on my D15 getting loose in the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 31 minutes ago at 9:45pm
Some dimensions would be great!
