What's wrong with this HD3 for $.01 ???
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: What's wrong with this HD3 for $.01 ???
    Posted: 03 Jun 2020 at 7:57pm
eBay item number 133423073389 is an A-C HD3 dozer in California with a starting bid of $.01 and no reserve. It was relisted because it got no bids the first time around. There's 17 hours left now. Am I missing something or are all the guys in that neck of the woods sleeping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 8:32pm
Maybe the CARB has poked some holes in the block?
Post a link, here, and someone will tell you...Hug
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2020 at 9:14pm
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 1:36am
Too far away for me!--would love to have it!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 6:31am
Location location location!
Sad, looks like a nice unit
Charlie
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 9:35am
Serious bidding will probably start the last half hour or 15 minutes. There are Apps out there to automatically bid a certain increment higher until your set bid max each time someone bids. Fun to watch the bids roll like the deficit counter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 3:36pm
Winning Bid was 2 Centavo's.  Amazing.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 5:15pm
Wow, thats sad. Would love to have that if it were closer to home.
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 8:07pm
I saw that the first time it was listed. I almost decided to drive to California from Georgia to get it. Then I remembered that we are in Covid time.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 8:38pm
GEES... the thing has to weight several tons... At $100. ton it would be close to $1000. just for SCRAP......... If the motor or trans is toast, i would think there are still a LOT of GOOD PARTS.... Problem is getting TO it and LOADING it.
OOOPS........ Tractor Data says 7600 pounds--- 4 tons... so $400 SCRAP......... but easier to move !!
Edited by steve(ill) - 04 Jun 2020 at 8:40pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 11:42pm
do good to get 20.00 a ton right now for scrap
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 8:54am
Hopefully someone bought it for parts or use and not scrap.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 11:20am
Not good when  people that want  cheap don't want it. Shocked
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 12:42pm
I couldn't afford to get it here even for 3 Centavos. Unhappy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 12:57pm
Didnt sound all that bad........
Tractor Dozer Allis Chalmers HD3 Scrap or Repair. Condition is salvage/repair/parts. Local pickup only.
Running when shut down 4 years ago.  Reason for shut down = leaking final drive axel seal.   Parts are generally in good condition.
Tracks in good shape.  +- 30 hp diesel engine, good shape when stored.  Transmission and Final Drive, except seal, good shape.
Weighs About 8500 lbs.  I have excavator that can help load for you.  (We will discuss your need).  Tractor is accessable.
Blade is 8'  6 way, hydraulic tilt, manual angle.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 11:49pm
Mel and Ray, where were you?
