what's everybody else using,,??
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: what's everybody else using,,??
    Posted: 29 Jun 2019 at 12:34pm
 Boy,,I'm slowly learnin a lesson in economics,,,,,I got my " Re-engineerin modification" done on the floor jacks that Ms. Red Head gave me and the first one was a little low on Jack oil,,so I say,,,NO Problemo and go to Walmart,,but they don't carry Hydraulic Jack Oil any more,,and the dude in automotive does not know,,WHY,,,WTH,,,?? So I go to Autozone and they gots one dinky little bottle left and that dude can't tell me when they will get some more,,,,What the double he**!!!
 OK,,what do others use in place of the jack oil?  Power steering oil,,,Brake Fluid,,,,hydraulic tractor oil,,,anybody???
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 1:20pm
Not sayin it’s right but I’ve used straight hydraulic oil, power steering oil and even ATF in known leakers.
Businesses are starting to not carry anything out of the ordinary. Everything is going mail order. We deal with it at work all the time. We have to order material packages way ahead of time for each job.
Also don’t forget it’s a throw away world now days. If a jack is low on fluid throw it away and go buy another.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 1:25pm
Hydraulic oil or steering fluid would be best.. Some of the NEW transmission fluids have a lot of MAGIC in them... If you use trans fluid, stick with the OLD ATF......... I would not go with Mercon or Dextron .... just in case.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 1:25pm
10/30 motor oil, ATF, snow plow hyd oil, Mobile DTE Lite,
Bought a floor jack at Goodwill (on old peoples day) for $15 . seems it would pump up about 5" - low on oil and works great now (was one of them $100 Taiwan made orange units) rated 2 ton
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 4:23pm
That's all that's out there now is Mecron and Dextron fluid ,, use it ,, simple
Edited by DougG - 29 Jun 2019 at 4:24pm
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 5:06pm
I always got it for the tire shop from NAPA. Our NAPA store has been here and owned by the same family since 1932. They have almost everything. The great great grandson is now working there. Hesgetting good.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 7:54pm
If it's a slow leaker, put in brake fluid. It'll swell the seals and you're good to go.
This page was generated in 1.598 seconds.
