What years B/C pto had no hydraulic pump mount.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: What years B/C pto had no hydraulic pump mount.
    Posted: 10 Apr 2022 at 6:48pm
I was looking at a Frankenstein B today (assembled from many dead B tractors). It had a driver's side belt pulley pto, but no opening/mount on passenger side to accept a hydraulic pump.
What year B's had pto w/o hydraulic pump mount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2022 at 8:46pm
Personally i have never seen a "B" without a least a cover plate where the pump mounts.... But you have to remember a "B" was originally designed to replace a horse and the GOAL was to PULL an implement... not much lift needed.
The EARLIEST "B" i have is a 1941.
Edited by steve(ill) - 10 Apr 2022 at 8:50pm
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2022 at 8:59pm
My 1937 B and 1939 B have no place for a hydraulic pump
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2022 at 10:08pm
My 38 does not have one but my 1940 has a pump on it, now could it have been added later? Yes, entirely possible as most of these have changed hands several times since new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2022 at 4:27am
The answer is that as things improve, they change, so the early b's may have no provision for the pump, but as design is fluid and changing, later tractors will have the pump mount and the PTO.  Look at the serial number, in front of the shifter, look it up, and trace the number to find the year.Wink
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2022 at 10:05am
Of course the original B tractors did not have the hydraulic pump.  However, they did have provisions for a PTO.  The original PTO's did not repeat did not have the configuration to add a hydraulic pump.  You may have seen some very old PTO's that did not have the side opening for a hydraulic pump.
That said, any B tractor could have a hydraulic pump added.  You would just get an up to date PTO configured with the hydraulic pump plate and add the hydraulics.
Therefore, any B tractor could have a hydraulic pump added.  Remember, the PTO and the hydraulic pump was an add on.
In fact when we sold them there were very few B's that did not have a hydraulic pump.
Good Luck!
Bill Long
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2022 at 2:34pm
When I got my C in86 it didn't have a PTO the old allis dealer had several no hyd pump PTOs in the back but none with hyd pump they they wear removed to add a pump to early. B's
Edited by Dakota Dave - 11 Apr 2022 at 2:35pm
This page was generated in 0.127 seconds.
