What would cause a tractor to stay running
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: What would cause a tractor to stay running
    Posted: 09 Jun 2018 at 3:07pm
Ran the 6080 for 4-5 hrs no issues.
Went to shut it off and key wouldn't kill it.
Pulled wire off injection pump to try and stop fuel flow, still running.
Final shut fuel off
Went back 30 min later to see if ignition switch was bad and it cranked over no problem
I just replaced switch last week
Anyone run in to this
This tractor is wearing me out
Thanks guys
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 3:42pm
Electric fuel shutoff?  Maybe it's sticking.
AaronSEIA
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 3:56pm
I would say if you took the wire off the pump and it still ran it has nothing to do with switch it's definitely pump issue hook a test light on the wire turn test light on and off with key
Edited by bradley6874 - 09 Jun 2018 at 3:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 5:54pm
some pumps have a shutoff solenoid, DK whether 6080 has one, but they do go bad, just like any other electrical part...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 6:30pm
Any way to turn it off it happens again besides turning fuel off
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 6:41pm
Put it in the highest gear, close throttle, apply brakes, slowly let clutch out.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 9:47pm
You probably have a bad fuel stop solenoid. Best way to kill it is block the air intake. Turning the fuel off cavatates the injection pump.
