What were "factory" AC duals?
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Topic: What were "factory" AC duals?
    Posted: 19 Feb 2026 at 8:29pm
So could tractors like the 7000/8000 series be ordered from the factory with different type of duals? i.e. clamp-on, cast, hub, mexican hat etc. or were those mostly "dealer installed" ?   I assumed that Cast style were more factory ?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 9:21am
Clamp ons were usually dealer provided aftermarket. Mex hats and cast were always selected from nearly a page long list of options.  Of course there were 2 or 3 different lengths and sizes of axles that had to be spec'd as well. At times with or w/o tires.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 10:50am
When my Dad and uncle were in business (mid-60's to late '70's), I never remember seeing a new tractor come from West Allis with duals.  Duals were always added at the dealership.  As I recall, most were clamp-on duals.  I don't remember any axle duals but there may have been a few.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 11:03am
Duals were dealer installed, not factory installed.  Clamp on duals were provided by the aftermarket.  Flower pots and Mexican hats are informal names for the cast centers that factory duals had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 11:20am
I think 7580's had a "clamp-on" factory ordered dual wheel. Seems like they had some sort of interlock notch on the dual wheel band to engage with the inner rim so it could never spin. A fancy set of clamp-on's for lower cost and in the case of a 7580, something not so heavy, as the tractor was heavy enough as it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 11:55am
Thanks guys, I always kind of wondered about that. I am debating what to out on my 8070.  It current has clamp-on, but the tires are shot.  I put hub duals with pressed wheels on my 210 years ago, and like that set-up, but was considering the more original cast set-up for the 8070.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 12:37pm
Ive never a sales brochure for a 7/8000 series with anything other than cast centers and i dont remember anything other than spinouts
Ive got a 8070 that because if the inside wheel setting and intermediate axle length im going to have to use mexican hats but ive got a set
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 1:20pm
I just watched a youtube on Allis brochures for black belly 70xx series, all showed the cast center with the spin out wheel.
https://youtu.be/U2KXUqCJKic?si=CLrwWF2k4p7EFyUb
Also watched a J and L video a couple days ago also showing the cast center with spin out wheel.
https://youtu.be/hJw9kVu9shk?si=hYaEDLQbZqMpjzuS
I'm not saying that is what came from the factory, just what I have seen in promotional material.
Ted
cornel b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornel b Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 3:04pm
all 7000 and 8000 tractors at dealer i worked at had cast duals
4w-305 7040 6080 6060
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2026 at 3:57pm
7580,8550,4W's all had options of clamp on duals.
Also after some research ALL the 7000 black belly tractors and 8000 had factory dual options that were clamp on - actually draw bolt on - they did not have the T rail - used over the rim clamps.  18.4 and 20.8 -38
Edited by tbran - 20 Feb 2026 at 4:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2026 at 8:01pm
Very interesting !!  I believe I have enough room to get 9-10 bolt hubs and pressed wheels on, but not sure on the cast. I will probably have a lot easirer time finding the hub/wheel set-up.  thanks for the replies!
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2026 at 10:19am
Sales brochure for 7030/7060/7080 has cast centers with spinouts.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2026 at 11:15am
We have an 8070 with axle mount 9 bolt 20.8 x 38 duals. With the wider finals of the 8070, there's barely enough axle. The hub actually sticks out past the axle a half inch but we've never had an issue so far. Also have an 8050 with dmi 10 bolts axle mount 18.4 x 38. It also sticks out past axle a bit.
Leon B Mo
