What transmission fluid to use in AC forklift |
ajdesmarais
Joined: 30 Apr 2014 Location: United States Points: 2 |
Topic: What transmission fluid to use in AC forkliftPosted: 30 Apr 2014 at 11:50am |
Hey, I've got an old 4000 lb Allis-Chalmers forklift where I work, the model is C-40, serial number is 172532. I need to refill the transmission fluid, but I'm not sure what to use. The gearbox is so dry I can't even tell what it has in it right now. Any advice would be appreciated, thanks!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 30 Apr 2014 at 12:05pm |
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 07 May 2014 at 10:10pm |
if its a power shift it should be atf
