What to use for a garden tractor puller?? |
Page 12> |
KevinON ![]() Orange Level ![]() Joined: 07 Dec 2009 Location: Schomberg, ON Points: 801 |
![]() ![]() ![]() ![]() ![]() Posted: 04 May 2010 at 8:41pm |
In a couple of years, my son will be able to compete in the 4H garden tractor pulls, and I was wondering what AC tractor would be good for this. Right now, all that I know is that it must be under 20HP. Just wondering if anyone has any experience with this? All my experience is with modified farm stock and pro stock tractors!! Thanks.
RSallis-pullinMD ![]() Bronze Level ![]() Joined: 14 Sep 2009 Location: Easton MD 21601 Points: 37 |
An 716 6 speed or 710 6speed same tractor different hp engine used to have 716 6speed my son and myself pulled with.All you need to do is change the a series drive belt to a b series and it will hold in pullin situation Very easy to change gear ratio by using cheap weld a hub and pulleys.
Cal ![]() Bronze Level ![]() Joined: 14 Sep 2009 Location: East Woodstock Points: 174 |
My son used to pull a B12 with an 8" pulley on the trans. He's 36 now ,but I can still remember the grin the first time he beat those JDs & cub cadets. something about the way those old cast iron Briggs pull & lug down. Note on those ol Briggs leave the points, the electronic ign. goes away at low rpms. Cal in Ct
DREAM ![]() Orange Level ![]() ![]() Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
I don't know about what AC mowers had what, but if you could find one that had an inline drive with a shaft and clutch system like IH did on the Cub Cadets, you would be ahead of the game with getting power to the ground. I have some freinds who used to pull GTs. I'll ask them if they know. The old B series ACs were pretty stout for belt-driven machines, as well as some of the early Sears(Roper-built) tractors.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7506 |
The AC 620 and 720 are conservatively rated at 19.5 hp. Are hydrostats allowed though? At 1300 pounds they've got the weight you need!
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
i've seen alot of ac 310's pulling, i've got one but not for sale, and alot of local pullers keep hounding me for it! so it must be a good puller?
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
I've got a Simplicity 3415 S I need to get rid of. Anyone interrested?
Dusty
farmtoybuilder ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
We use a B-110 with 12hp. briggs in it. Does well in stock classes! We have double clutch springs on it and B width belt. Weak point is axle tubes And side differential gears on any of the AC's and simplicity's. All brands have their weaknesses.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6077 |
Regardless of the tractor pull, the winner is always the sled, and the
determining factor is the rules. The Wismer-Luth agricultural tractive effort prediction boils down to ratios- weight of the tractor, proportion of weight between driven and undriven wheels, and the diameter of the driven wheels. Once the wheel starts to slip, the amount of drawbar effort available rises in very small increments with addition of large amounts of horsepower.
SO... regardless of what you use in pulling, weight is a key factor, hence GT pulling is usually categorized by weight class. Don't take a knife to a gunfight- make sure your machine weighs in at the maximum allowed, and keep that weight under control. As Jeff noted, garden tractor drivetrain weaknesses are usually the biggest issue. Many manufacturers used belt drives and lightweight transaxle assemblies, oftentimes wet clutches buried inside an aluminum housing... many Peerless transaxles are that way. The defining feature of true 'Garden tractors', are that they're intended, from the git-go, for 'ground engaging implements'... this means tractor-pulling was part of the intent... mebbie not against a sled, but against a plow. Serious garden tractors have heavy drivelines, strong axle tubes and shafts, stout clutches, and engines that live long and develop high torque. Easy way to find these guys- pick up the back half. If you can lift it, it's not stout enough. EVERY type of driveline has it's limitations. Using a belt-driveline system usually defines your power limit very early. The maximum amount of power transmittable by a belt is determined by the belt shape, tension, and amount of tractive surface on the belt... aka 'wrap' surface. There's plenty of good information out there, and Carlisle has a belt selection program that will identify the maximum amount of power that a belt can reliably carry... if you plug in the numbers for a variety of common setups, you'll find that shaft-driven drivelines have a distinct advantage over belts. Hydrostatic drivetrains, although very capable, tend not to be used for competition, because the hydrostat is horsepower-lossy in comparison to gear-drives. Most rule-books will have some stipulation that once the hydrostat speed has been selected, it cannot be changed, so running a hydro puts you at a disadvantage. I haven't seen many incidences where a belt-driven machine out-pulls a shaft-driven, but where they did, it was simply a matter of operator skill. I've also seen many pulling tractors that wore one company's colors, but had a Cub Cadet gear-drive rearend. Why? Because the Cub Cadet rearend is the same as that used in the Farmall Cub... right out of a genuine farm tractor... heavy iron, oftentimes fitted with a ring-and-pinion out of a Dodge Dart, and fine-spline axleshafts... there simply aren't any other 'stock' rearends out there that come close. Kohler K-series motors appear to dominate stock classes, and if you like to 'work' on your engine, and the rules allow, the 'small' 12hp engine frequently responds best to modification... it will typically survive best making much more power than the 14 and 16hp blocks, albeit you'll have a special head, crank, and flywheel, very high governed RPM, velocity stack, and all sorts of other crazy things... and when you get it 'right', the dyno will be up around 45hp or so... (and your wallet will be really, really empty). But if you concentrate on the concept that it's supposed to be FUN... pull what 'ya brung, and ignore what the other guys do... look at the track, hitch up, wait for the flag, and when it's time, realize that it's you against the track, and the sled ALWAYS wins. At the end of the day, if you come home with mud in your hair and a smile on your face, you did it right. |
Good ![]() Orange Level ![]() ![]() Joined: 05 Apr 2010 Location: Logansport IN Points: 453 |
My Dad pulled a B-212 that has 3 speed with variable,he used 3 springs on clutch and the variable belt is about 2 inches wide and is real strong.He had it weighing 1000lbs. with operator and never broke anything.But I split the outer axle tube open plowing with a 12inch bottom inside an old barn foundation, but the tractor was only 30 years old at the time.By the way Dave wouldn't a panzer rearend exceed a cub rearend? when I was a kid all my friends that's parents had cubs where constantly working on the drive and mowerdeck cluthes,not to mention the mowerdecks are terrible along with slow steering and then not sharp turning.My opinion is that pulling is the only good use for a cub.
Nathan ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: ohio Points: 381 |
I have a 716 that is set up for pulling just needs a motor if anybody is interested let me know and i will get you the information on it. thanks nathan
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2223 |
I always wondered how well one of those old Gravely 4-wheel lawn tractors would do in a pull. They sure are built strong enough for it, with no belts and the engine in the rear. I would think an older Allis mower with a little modification would be good too. I would probably go with a 310 or something similar (314 maybe?).
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
I used a Cub 1811 (hydro) to mow for 20 years with no issues.
I think a gear drive will outpull a hydro of the same weight due to power loss in the hydro
Charlie
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12000 |
From what I've read, the Panzer had a 8 3/4 Chrysler rear end in it. Quite stout for a lawn mower! I wouldn't think there would be a lawn mower engine no matter how large and powerful to break that rearend.... lol!
rich ![]() Bronze Level ![]() ![]() Joined: 30 Mar 2010 Points: 26 |
Is the. B110 the same as a simplicity 2210, I thought it was but I have a 10 hp briggs
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Think I would go with a 5015. I don't think it's over 20 since my 5020 is just barely, and if you got a four wheel drive model you would beat everybody! No modifications necessary, just go stock!
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3529 |
guys that run the AC's (simplicity) in the B series or the 700 series take out the bevel gear box and replace with a superior or other right angle gear box, use pulleys with a c belt as stated above on a gear drive unit and replace the rear axle with a solid shaft. Local rules may not let this be done. Stock trannys are only good for about 25 -30 hp long term. If one wants to show the colors, there are web sites that specialize in cub cadet special built tannys, clutches and axles - these will last and ac be put under what ever sheet metal you choose. . |
Just wondering about the old(60s to early 70s) Sears garden tractors. I had a 1973 ST-16 with a single cylinder Tecumseh OHV engine. It had a manuall 3-point hitch lift. I plowed old ground(had to bush hog scrub pines about 2" in diameter to clear land) with a single 14" plow with turf tires and fluid. I had to lean back on the lift handle some to get the plow in the ground right, but it did a great job. Plowed about 8" deep, and didn't spin out much. This tractor had a solid cast iron transmission/transaxle with dual ranges, cast outer axle tubes, and 5-bolt hubs on one-peice axles. I would think that this transaxle would be plenty stout, along with the rest of the tractor. You would just need to beef up the belt drive, or put on a right angle gear box and shaft drive it with a clutch system.
Has anyone tried pulling with these?
I've seen a Panzer at a show, but never on a pulling track, so I couldn't tell you what to expect, but the smaller automotive differentials, where allowed, are prevalent in any application where they'll fit. Typically, you're getting a stronger carrier.
Dream- that Sears unit was definately a tough bugger, and the OHV Tecumseh was, in many ways, ahead of it's time... I have same engine on my Miller Bluestar welder. It ALWAYS comes down to rules... no matter what the situation, it's all about the rules... and there's two rules about rules: You can't win if you're caught and disqualified for breaking the rules... and You can't win if you don't push the very limits of the rules. And while I've been known to hook up to a sled with both garden AND full-sized tractors every once'n'a while, I've never done competetive pulling. I've built a tractors for doing draft work, pulling trees, locomotives and railcars, wierd implements, and other purposes, but not for competetive pulling, never hooked up to a sled for any reason other than being able to put a machine under a load, and try my hand at beating the track, and the sled... and of course, the sled beat me every time. ;-) |
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
My father restored maybe 50 cub cadets over many years as a hobby, any gear drive one that was purchased was immediately striped of its trans axle for sale to pullers, the other parts went to resurrect hydro models. If you go to a tractor pull, even the john deere and other brand mowers will typically have a cub rearend, sometimes the rear, frame, and front axle. They will just put their favorite brand sheet metal on.
Good-
Do to the airflow being lousy, cast-iron (square-end) factory mower decks are poor by modern standards, but they were incredibly tough and effective for their time. Later stamped-steel decks are substantially better, but metal had to be thinner and softer to accomodate the stamping process. They're still stouter, thicker decks than most others of the time. During the early '70's (before the stamped decks came about), the best deck designs came from companies that made fareway mowers... the big Toro, Howard Price, Woods. Once airflow concepts trickled to the home market, that all changed... I think the big commercial Simplicities really started the wave, and Gravely really pushed it into the consumer market. The Cub Cadet hydrostat driveline's biggest weakness is the cross-pin on the engine drive coupler. Gear drive's biggest weakness is again a pin on either the clutch drive or gearbox end. Many guys, not knowing, replace these pins with conventional roll-pins, when they NEED to be a Spi-Rol pin (a piece of high-tenstile spring steel with several turns wrapped into a pin), hence, the engine's power shears them readily, tearing up the shaft and bore for future problems. Note that the spi-rol issue shows up in MANY garden-tractor applications, so this problem isn't limited to any one brand of GT, and extends to implements as well. It is also more prevalent in high service-factor, high-power/high-traction applications, so larger single-cylinder engines will break them faster than even larger-displacement multi-cylinder engines. Must guys either correct them properly, or use industrial U-joints. My IHCC loader runs SKF U-joints and hardened pins for that reason. Steering slop is the result of lots of use, and eventually proves to be a limiting factor of steering angle. Many garden tractors of the vintage used the same ROSS worm-sector steering system, and all used tie-rods and drag links. Careful inspection, proper rebuild, repair, and adjustment solve most of those problems. The converse, is siezed components, which is either caused by no use or maintenance, or use of incompatible greases in fittings. Mixing lithium, sodium, or molybdenum greases results in saponification- greases ionically recombinding to form something akin to 'stone'. This is typically followed by somone 'forcing' the steering, and causing damage to other innocent components. As for being good for 'only pulling', that's a statement made of passion, not logic or experience. All garden tractors intended for 'ground-engaging implements' have many uses... they are, after all, built with the intention of being worked hard. I have a Johnson Workhorse loader on my 'mutt', and there are some pretty substantial hand-fabricated parts and a whole lotta ballast to make it pick and carry 500lbs, but the transaxle and frame is actually bone-stock. It's a shame, but suffice to say that nowdays, most products are made to be 'sold' rather than worked... and while prevalent today, that same concept DID exist 30 years ago. In all cases, it's all a matter of picking the proper tool for the job, and realizing that tool's limitations. Likewise, when doing competetive pulling, it is particularly necessary to know those limitations, as you WILL find 'em... because if you don't, you won't be competetive. Edited by DaveKamp - 08 May 2010 at 11:43am |
Jordan ![]() Bronze Level ![]() Joined: 31 Dec 2010 Points: 1 |
Just wondering if a 912 shuttle shift would be a good puller?
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
As another posted, find a manual transmission-----not a hydro. Too much power loss.
Then read the rules carefully. If 2 cylinder engines are allowed (or allowed in some classes) try and find an Allis 920 or Simplicity 7790. These were only made in 1984 and 1985 and had a 2-cylinder Lombardini diesel engine. It was conservatively rated at 18+ hp. But it has an injection pump that can be adjusted (big smiley). Find a gear drive 916 to start with and learn the driving, tire and weighting tricks and then swap the diesel into it. Edited by 427435 - 31 Dec 2010 at 11:31pm |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
get him an AC 920 diesel!
I have a rather old Simplicity for sale. I'm in Florida for the winter and not 100% but I think it's a 3114 4 speed Shuttle, single cylinder Briggs engine.
Dusty
Fred Olsen ![]() Bronze Level ![]() Joined: 04 Mar 2021 Location: United States Points: 1 |
I want to share with you the catalog of tractors, there is a lot of useful information and characteristics https://tractorid.com/ , I am sure you will find answers to your questions.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5238 |
Interesting thread before my time on the forum, I always wanted to know if anyone pulled a 720 before. At 1,300 lbs I always thought they would be stout since I feel they are built very well even though they were a hydro. Even if limited to a single speed, 1st gear in full forward hydro should produce some good power IMO.
And yes it should be in the garden tractor section, I didn’t put it here. Just responding to an interesting thread.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3090 |
The old MTD garden tractors with the drive shaft and the fiber clutch would seem to be a good choice,also the small Bush Hog garden tractors with basically the same set would be good.I've run both and never slipped the clutch on either.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54161 |
Best pulling tractor, I ever owned was a Gravely 816. Hadda twin pancake Onan 16 motor, mounted in the rear. I pulled a hahn westport 42 inch core aerator with it, for years. On some hills I would turn around, and sit on the hood, to keep the front end down! Don't know how it stacks up, weight-wise, but it was a bullet-proof unit, weakest part were the welds in the steering gear.
Page 12> |
