What the hell were they thinking...AC 175
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 7:30am
Your title describes the 100-200 series to a T minus the 160. Seems like they went backwards from the D series.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 7:51am
It is what it is , til you are done trying to change it ,you will have more time in it then just getting someone to help you for a few mins .  Wheel never fell off so what they done worked . Good luck .
nonetheless ,still dead.
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 5:51pm
Take the rim off of center. Leave the center on the hub or take the center off afterwards.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 6:27pm
Will someone PLEASE post a pic of the "issue" at hand ??!! Thanks Wink
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 11:11am
once upon a time..we drilled out the holes to accept E combine studs and then the nuts..Mark
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 12:50pm
All but one of my 175-185's have the nuts on the back...it pissed me off the first time as I had a flat and it was hard to spin out the wheel to get to the nuts. Now I just take the time to spin out the wheels first, use 2 vise grips and take two lug bolts off at a time. It goes pretty fast. I play musical tires alot, so I have it down to a science. 38" centers are easy, not necessary to spin them out. I use a long screwdriver to hold the bolts in place while I put the nuts back on.  I had a set of threaded spacers that I put on one tractor so I didn't have to mess with the nuts....
ALLIS EXPRESS!
This year:
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 3:37pm
X2! I’m not familiar with this series tractor so a visual would be nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2020 at 8:34pm
The two things I really dislike is the throttle on the gassers, and the battery placement on both. Other than that I like most everything else. I have not had to deal with the nuts on the rear hubs yet though! Tracy
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 7:04am
I agree on those two items but the rest is generally better than D series IMO. Especially the power steering. I like my old 190 and my 200 way better than my D19 and I'd take a 170/175/180/185 over my D17 6 ways from Sunday..... but my D17 is not a Series IV.
Wink
I am a Russian Bot
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 7:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 3:15pm
So what's the end result with your studs and nuts
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 3:29pm
Well I did get them off with much struggle.  I just needed to bitch about it!
This page was generated in 0.101 seconds.
