What the hell were they thinking...AC 175
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: What the hell were they thinking...AC 175
    Posted: 23 Sep 2020 at 7:04pm
So I want to take the tire/hub off the tractor...lug nuts are loosened but wont come out...well,  who the hell thought not threading the tractor side thus requiring a nut on the other side of the bolt was a great idea!?    Cant even see the nuts!  Had a hell of a time getting the wheel off as I was by myself.....I had a tractor tire service guy out  to retube fill my WD45 tire and he thought it was bizzare too.....Oh btw, after filiing the old tire on the WD45  fluid, the tire blew off the rim and the water blew out the new tube....guy says tire too tired cant hold pressure that was called for........I always keep the tire underinflated for better traction guess thats why I never had a blowout.  If it was overinflated it wasnt much.  Funny thing is 10 min prior win filling he said in the 8 yrs doing was nervous in the begging of this line of work about over pressureing..but said never had a blowout.....I told him you just HAD to say that!!  Oh well better there than out in the field...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 7:46pm
I went that on a One Eighty- thought the hubs were threaded, nope a nut on the back and a few hours ,, uuggggg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 7:54pm
Renter has a 4020 (ICK) Deere that way. asked about helicoiling them, said not worth it but will spend a couple hours fussing and fighting with the nuts to get them tight.  Cheaper to buy hubs for all the wasted time.
wayne IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:24pm
The hubs from the factory had threads until neglect or abuse with a wrench removed the threads and the person simply added nuts rather than fixing it correctly by either replacing the hub or using a heilicoil.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:35pm
I am sureTom is on the rear wheel not the front!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:41pm
Yeah this is all rear wheel action- the fronts are bad enough unless you put 2 studs across from each other
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:43pm
The center bolts on the rear hub are also threaded into the hub from the factory though.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:47pm
Someone has tampered with those wheels.
Wink
I am a Russian Bot
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:49pm
170 (maybe), 175, 180 and 185 all have nuts on the rear lug bolts.  There are no threads in the hub at all.  They definitely are a pain to work with.  Makes you think twice if you really need to remove the hub.  They are much easier to deal with if you remove the rim first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 8:53pm
Just different enginering thoughts on that series
Edited by DougG - 24 Sep 2020 at 4:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 9:01pm
Looking at the parts book for the 175 and they do list a lock nut for the center bolts, but they also have a serial number break on the center bolts for 2 different part numbers.  Don't know if the nuts were added later or what the change is.  Been 20 years since I had to take a tire off the neighbors 180 to rebuild the brakes, I don't remember there being nuts on the inside of the hub.  Looking at the 180 parts book though and it shows a serial number break for having nuts behind the hub, so the neighbors 180 must be a lower numbered one.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2020 at 9:10pm
OK for some reason I was thinking front wheels because I've seen stripped hubs with a nut on the back side. Second, even though I have worked on a few 170's and 180's where I had to take the rear wheels off and I never saw one with locking nuts on the back side, I guess I learned something new and totally agree, what a stupid thing to do.
Wink
I am a Russian Bot
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 6:02am
When I swapped wheels on my 180 the hubs were threaded just put the lugs in just like on any other wheel,if there are nuts on the back side the threads have been stripped out usually the result of an impact and cross threaded  lug.Several on the front  of my 180
require a nut.I just run a grade 8 bolt in from the back side and use lug nuts on those.
If I needed to I'd do the same  on the rear hubs and tack weld the bolt heads.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 6:16am
Yep they been there a long time .Unless a axle seal is leaking or you need to replace wheel center NO need to remove them .And I never remove  wheels when doing brake jobs .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 6:26am
The original design was threaded into the hub and with the introduction of the ONE-EIGHTY, it took them a few years to figure out when the tractor was dualed up and weighed 9000 lbs the old design FAILED. So, they went to a larger diameter bolt with a lock nut and no more failures. Good design change because it was needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:06am
Yeah there are NO threads on the tractor side...smooth..as to removing the wheel first...yeah that wouldve helped.  Dont think I had the muscle to slide the tire off the rail...tractor is dead and brakes froze up.   If I had another person to hold the wrench on the nut and me on the outside with the ratchet it wouldnt of been too bad....  Do you think it would be wise to get the holes tapped out to fit a lug and not have to go thru this again?  After all the  whole final drive is coming off and apart.  would have to drill the rim hole a bit bigger too I assume
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:15am
I have no idea why you'd want to do that. The design is just fine and nothing ever works loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:24am
Well, to eliminate the pain in the ass in taking them off is a good enuff reason for me!
The WD45 is threaded, I assume the D17 is as well...what was the rational of going awaty from that?   Tire service man thought it weird too...and he has seen lots of tires...
Edited by TomYaz - 24 Sep 2020 at 7:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 7:26am
Bad enough I have to take off the final drive to get to the brakes...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 8:10am
The good doctor explained it well enough I guess. It was done because as the power and weight grew with that design the threaded hubs would fail. But I know what you mean Tom.
Edited by Lonn - 24 Sep 2020 at 8:10am
Wink
I am a Russian Bot
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 8:13am
Just a guess...but factory high crops had nuts to eliminate loosening....have two like that....
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 12:43pm
Looks like all late model 170 and 180 tractors and all 175 and all 185 tractors went that way.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 12:50pm
Once I did have to remove the wheel off a 185 to replace a broken rear axle. I just don't remember those lock nuts but it has been over 25 years ago since I worked at the AC shop.
I still have some of the notes I took on each tractor I ever worked on while there. The owner's name, the tractor serial number, hours and what I exactly did to the tractor. Unfortunately mice got into those notes pretty bad when I stored my tool box in the garage for several years. I remember the 185 because around the same time our neighbor's 185 broke it's rear axle (it was his planter tractor and still is today) and the 185 I worked on had the other axle break a few years prior. I figure AC let some bad steel into those parts for a time.
Edited by Lonn - 24 Sep 2020 at 12:51pm
Wink
I am a Russian Bot
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 5:00pm
Tom, I alway said that the world would be a lot different if engineers would consult me before they made any decisions.......OHBOY would it be different! LOL
probably not better, but different!
I am still confident of this;
Wait for the Lord;
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 8:39pm
EZ ? We have seen dozens of bolts strip off in the threaded type wheel. Then one has to weld, drill , tap... and wind up with an odd hole or so, not so with the non threaded axle.  Yup  takes 2 to remove or a special vice grip -but as stated,,, but why remove the center?
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 9:19pm
I have both a 170 and a 175D both purchased new.  Neither one has any nuts on inside of hub, even though the 170  carried a NI mounted cornpicker for 25+ years, which meant that the wheels had to be swapped to mount the picker(sets the wheels much wider), then swapped back when done!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 2:21am
Went and looked at my 185 never knew about that lug deal.What a terrible idea,please post what solution you come up because  if i ever have to pull the wheel centers off its going to be different going back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 6:39am
I need to get to the brakes.  I believe the brakes are rusted frozen.  BUT it could be frozen up in the final drive who knows.  In theory I suppose I could take the final drive off with tire on and all?, if could but dont have the right lift equipment to do that.
Well if I had a person to help it would have not been a big deal.  I got bruises on my chest from pressing up against the tires to do the reach's....And then of course afterward it occurred to me to deflate the tires to give me more room...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 6:43am
Yeah Dr Allis explains why they did it, but youd think they would have made the mount with deeper threads or something other than that.  The nut on the end was cheapest solution I would assume....  After waht DrAllis said, threading it out and putting in a larger bolt may be tempting fate....Tempting fate usually has me on the losing end.  Next time will be sure to have a helper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 7:25am
My 180 has the threaded in from the outside lugs like a normal tractor hub,it has been used pretty hard with right much weight on the rear at times with no problems.If there is room I'd just get some lug bolts that are shouldered to go into the backside of the hub.
This page was generated in 0.139 seconds.
