What Plow is This?
hardwood61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Topic: What Plow is This?
    Posted: 12 Aug 2016 at 6:21am
Just purchased this plow and have not even picked it up yet but the seller said he thinks it is a JD but I dunnno about that.  Figured someone here might know.
Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 6:47am
Should be a name stamped in curved beam just above curve.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 6:56am
I will check it for a number/name when I pick it up.  Also anybody know what is up with the linkage pins ... they look like bolts, never seen them before.  FYI this is my first 3pt plow so not to knowledgeable about them.
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 7:41am
Might be printing on back of moldboards, something like Syracuse Plow works.  They made bottoms for JD and several others.   If the shears (points) are forged, be careful in hard stony ground, they will break.  Will also break if you drop them too fast on a cement floor.  Don't ask, but they cost 50 bucks each!
Bill
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:03am
It's doesn't look like any John Deere I've seen before, but it looks like JD paint and there's JD stuff in the background. Could been made by someone else and resold by Deere for the smaller 320's or 420's. Oliver made a lot of plows for other guys. They made some plows for Ford.
You can use bolts for the hitch, but usually you'd use a linch pin. It's a pin with a loop on the end that folds down to keep the pin from coming out. Google Linch pin. You'll see what I mean.
Karl in MD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl in MD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 10:10am
Case Eagle Hitch from the looks of the pins and toplink tower.
A man's got to know his limitations.
'51 WD, Roto-Baler,, A-C rake, '44 C, '42 B
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 6:20pm
looks more like a oliver-stover plow' have one the tail wheel looks the same' look it over more' may find markings or numbers on bottoms..
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:10pm
John Deere's will have a "JD" casted or stamped on various parts. An Oliver will have "E****" or X**** casting numbers. Case's will have the image of "Old Abe" eagle casted in certain areas. Take a closer look.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Ben s View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 10:18pm
I also believe it's a case eagle hitch plow I know some of there plows were painted green also
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 12:54am
Dearborn made some with that curved style framework too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 7:07pm
Well I picked it up Yesterday and I have looked all over it and cannot find any numbers ... one thing that I found interesting is the lift pins/bolts are screwed into a heavy cast iron piece that is removable and adjustable from side to side.  Anybody ever seen one of these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 12:13am
there's one like it on an auction coming up. www.delpeterson.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 12:16am
listed under "planting equipment" , auction closes aug 23rd
This page was generated in 0.101 seconds.
